RTV On Intake Manifold??
zZsKyZz
503
I keep getting a weird feeling that where my upper intake meets the lower there is a small air leak... Same with around the TB and the TB adapter. The Edelbrock instructions say to install it dry, but I was wondering if anyone here used any type of RTV or Sealent?
Thanks guys. :nice:
I assume you installed a upper/lower paper gasket in between?
Make sure connections coming out of your upper intake are allowing it to sit down on the lower, flush.
I have heard people installing RTV to seal it, but it is something I wouldn't do for a cheap gasket price, that cost the same as the RTV tube.
You could pull the upper intake, and check for flatness on the upper and lower intake.
Same for the throttle body. What kind of throttle body do you have? If it is whistling:shrug:, it could be the throttle body.
