no theres no leaded fuel in bahrain .i run unlead fuel with 95 octane
Well, I can't see any reason not to convert over to an A9P then.
Do you have threaded bungs in the exhaust for the O2 sensors?
The other question is if the wiring harness is the same. It should be fairly close, but I am not sure how Ford would have dealt with the O2 removal. They may have capped the O2 plugs, or just removed them from the harness completely.
Maybe there were other changes made as well?
Here is a good source for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp
If your harness is significantly different than the US harness, then it may be easier to buy a used US A9P harness as well?
Hope we're helping, and wish you luck,
jason
PS-
If you do go through with the conversion, I would be interested in purchasing your old X0X computer. It would be a great learning experience for me.
Regardless, I will help in any way I can.
