runnability issues, help
  • Thread starter Thread starter hogieman
  • Start date Start date Jun 20, 2008
H
hogieman
  • Jun 20, 2008
I have a 1966 Mustang Convertible Restomod, with a 1992 5.0 rebuilt(2/07) .030 stock piston, stock heads, mild erson cam, 65mm throttle body, A9p computer, rebuilt AOD with shift kit and b&M torque master 2400 stahl, 150lph fuel pump, cobra intake, 19# injectors, 1 5/8" headers, stock distributor, ford racing coil, ford fuel injection wriing harness, 8" 380 posi.
The car starts and idles fine, runs up to 3000 rpm and it starts sputtering and back fires, I have changed computers, distributors, modules, wiring harness. I have checked timing and tried advancing timing with no luck, it seems as if the distributor starts to retard as the engine rpms climb. HELP!!!
Scorcher2005
883
South Carolina
Jun 20, 2008
  • Jun 20, 2008
If its the distributor...do you have the little pill plugged in?
Also, how do you have +.030 STOCK pistons?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 21, 2008
  • Jun 21, 2008
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
  • dan50
  • Jul 18, 2026
dan50
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
