I've always had this problem (code 41 RIGHT SIDE HEGO) I fixd a vaccum leak Purge vaccum) set the tpa and idle. The iab is suspect should top out at 6.5 ohms, mines 11.9. MAF clean, injectors seem ok and the timming at 13* fuel pressure at 35 pounds. So last night I disconnected the right side HEGO and went for a ride the motor pick'd up some. my next experiment is to hook up a volt meter to the HEGO harness and take a ride and see what their doing. I'll post that, I'll need some help. And yes the HEGO's are new.... any ideas are welcome....
