running a B.O.V vented to the atmosphere?
Currently I have a Mondo bypass valve that is recirculated back into the system on my car, but I was looking into running a b.o.v or a diverter valve that uses what they call an "anti stall" valve that will allow MAF cars to vent to the atmosphere without having issues. The MAF sensor is set up as a draw through configuration. Does anyone have any info or experience with this setup I am looking into, or am I wasting my time? The reason for doing this is I would rather sell my Mondo (make decent money off of it) and buy something that I could vent into the atmosphere as opposed to having to route back into the system. Any info would be cool.
The MAF meter tells the computer how much air is going into the engine. If you let air out by having the blow off valve after the MAF, the air/fuel ratio will be wrong (you'll be rich). If you use a bypass valve and vent the high pressure air back behind the MAF, the air still stays in the system and everything is OK. The OEM's use this approach on boosted cars because it is quiet.
If you want a blow off valve, convert your system to a blow through MAF. As long as you have the blow off valve before the MAF, it will be OK. The MAF will read air going into the engine after the valve and after the high pressure air has been vented.
