running great then quit
  • Thread starter Thread starter jt88gt
  • Start date Start date Aug 15, 2009
J
jt88gt
17
north carolina
Aug 15, 2009
  • Aug 15, 2009
car was running good, no engine codes or anything. went to get some gas, turned car off, filled the tank up, went to start it and would not fire. fuel pump was not running, checked for power (at inertia switch) nothing coming in or out. just ran a hot wire to connector, pump came on car is turning over but will not fire. checked for spark, not getting any. is there a common wire or module that would be sending power to the coil and to the fuel pump?
HISSIN50
34
129
Aug 15, 2009
  • Aug 15, 2009
The PIP, with a conduit through the TFI module, controls both. It could be either one, though foxes tend to go through TFIs quicker than PIPs (TFI's are generally heat sensitive, whereas PIPs randomly act up).
Let the TFI cool off and see if it catches. If you go into the store and buy something cold (frozen peas, etc) and wrap the bag around the TFI module, this might help expedite the testing.
J
jt88gt
17
north carolina
Aug 15, 2009
  • Aug 15, 2009
Stupid question. I know what a TFI is but what and where is a PIP?
HISSIN50
34
129
Aug 15, 2009
  • Aug 15, 2009
PIP is the ignition stator inside the distributor. It tells the EEC where the engine is at in its rotation, so spark and fuel can be sent to the correct cylinder at the correct time.
J
jt88gt
17
north carolina
Aug 16, 2009
  • Aug 16, 2009
thanks alot, im going to check that out today.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
