RUNNING HOT
lmpbzkt492
68
hey guys i got a problem with my 91 GT that is giving me problems. Start the car up and let it sit there with the AC on and once it comes up to operating temp the needle will barely move if just a little bit maybe. Get out on the highway needle starts creeping up on me. Put the AC on the the needle will go up to say about 235. Most of the time i have to drive with the heat on in fear that my car will overheat. Have a 1 year old radiator in in (two row) and a 180 stat. Also after driving it, when it starts running hot, i can pull over and let the car sit and the needle will slowly drop. The guys i work with seem to think it is an airflow problem but i have no idea. any help would be great.
Sounds like the fan clutch. My brother in laws 93 was doing exactly what you described and I replaces his fan clutch and it runs perfect now. Get the heavy duty version. Without seeing the car I'm as positive as I could be.
PS: I think that your co-workers are right.
I'll respectfully disagree. It cools off and runs fine when idling but runs hot on the highway - that's not the fan clutch or fan blade.
Do you have the little air dam under the radiator? On a GT, that's pretty important in getting air flow through the coil.
Good luck.
the air dam is there. it has two cracks in it but structually it is the shape and in the location it should be. but from what i can see when looking under the car, there is not much room between the condenser and the radiator, where the air is suppose to be pushed up in front of the radiator. there is maybe less than a quarter inch.
Is there oil or grime around the fan clutch? If it was winter time I wouldn't be so sure but with the high temps that we've been seeing the incoming air hitting the radiator at highway speeds very well may not cool enough without the fan working properly- especially under load.
perhaps adding some water wetter could help cool the system down a little. this would be a bandaid fix since it isn't addressing the cause of the problem but it should lower the temp of the car. anychance your rad cap need replacing?
just replaced the rad. cap the other day. pressure tested the old one was only holding like 3 pounds. thought it was goin to fix it but obviously not. anyone else have any ideas?
I always check the air condensor. It may be clogged with dust, dirt, bugs and white fuzzies. I blow mine out every year and you woudn't belive the crap that comes out. Try that simple easy and free
