  • 1994 - 1995 Specific Tech
running lean, vacuum leak??
  • Thread starter Thread starter 5literstang
  • Start date Start date Dec 20, 2007
5literstang
1,374
Clark, NJ
Dec 20, 2007
  • Dec 20, 2007
my 94 gt seems to be running lean. i have the fuel pressure set at 39 idle and 45 WOT. when i changed the plugs they were frosty white. also i noticed a vacuum leak, right under the intake manifold and on the upper intake, when i capped it the car runs like crap and surges, and stalls when i turn the wheel. with it off the car runs alright but when i rev it, as the rpms come down it will stick at 2000rpms. any help would be appricated. thanks!!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 20, 2007
  • Dec 20, 2007
Sure a v leak could do that
Get em all plugged up and reset the pcm
Grady
GTA_V6_Mustang
1,326
Miami, FL
Dec 20, 2007
  • Dec 20, 2007
Grady
+2 A vacuum leak would definetly do that.
5literstang
1,374
Clark, NJ
Dec 20, 2007
  • Dec 20, 2007
ok guys im about to do that right now, il let you know how it turns out!!!
HISSIN50
34
129
Dec 20, 2007
  • Dec 20, 2007
The boys are right-on.
Your ISC function is probably nothing right now (your vac leak was basically performing the air-bypass function the IAC normally does). Now that you plugged the leak, the IAC didnt know to kick its butt back on (and you were stalling under the slightest load, like using the PS). Starting fresh like Grady said is the way to go.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
