Running Lean
  • Thread starter Thread starter dcurtis
  • Start date Start date Jun 1, 2007
dcurtis
688
Jun 1, 2007
  • Jun 1, 2007
Just got back from auto zone, had diagnostics ran on my car and the only code it threw was that it is running Lean, what could cause it to be running Lean? The car is completely stock engine wise. Thanks for any help
88mouse
630
Mooresville nc
Jun 1, 2007
  • Jun 1, 2007
vac. leak. did they tell you the number of the code? if so posted it up for us to see.
dcurtis
688
Jun 1, 2007
  • Jun 1, 2007
No they didn't give me the code, he just went straight back in the store looked it up and told me it was running lean. I'm gonna start looking for vac leaks tonight though, hoefully I will find something. Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 1, 2007
  • Jun 1, 2007
Dump the codes yourself & post the numbers. I guarantee that I will give you a better what’s broke and how to fix it description than AutoZone ever could for a 5.0 Mustang
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is less than $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
W
intermittent start and rough, high idle. 06 gt
  • Woe06
  • Jan 7, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 7, 2026
