Running Poorly
  • Thread starter Thread starter Hurtle
  • Start date Start date May 31, 2008
Hurtle
55
Jersey City, NJ
May 31, 2008
  • May 31, 2008
1965 289 2V
About 100 miles from home, my car starts running poorly all of a sudden while navigating a parking lot at < 10 MPH speeds. Poorly as in really rough and can barely stay running at idle.
I managed to get it home and start checking things. I pull a few plug wires and find that #7 has no effect on the idle when removed. The wire was sparking though as I could see the spark jumping to ground. I pull the #7 plug and it's clean like brand new. I then swap #7 and #8 plugs and unexpectedly, the problem stays with #7. Just for the sake of being thorough I then swapped the #7 and #6 wires and the problem still stayed with #7. I then sanded the rotor and contacts in the cap and that didn't help either.
So I'm now back to the coil or Pertronix unit. The Pertronix unit is hooked to the coil side of the ballast resistor and that arrangement has been working fine for 8 years. The spark plugs are Autolite 45s if it makes a difference.
I just figured I'd post here for opinions before I swap the coil. What are the odds this is a fuel starvation problem that just affects one cylinder?
Thanks for your comments.
Hurtle
55
Jersey City, NJ
May 31, 2008
  • May 31, 2008
Update - Plug wires 1 and 6 have no effect when pulled off either. 5 and 8 do. So 1,6,7 are problematic and i stopped after that because I was getting burned.
Assuming half the cylinders were problematic, I turned the idle adjustment screws all the way in. Doing so on the driver's side stalled the engine as expected. Doing so on the passenger side had no effect. The gas shoots down both venturis when I pull on the throttle though.
OK. So it looks like the idle passages on one side of my carb are blocked up. Fair assumption? I'm suprised the car can run at all on half the cylinders. Anyway, would the next step be a carb rebuild or can I pass this thing like a kidney stone somehow?
ashford
485
fargo ND
May 31, 2008
  • May 31, 2008
ill bet #4 doesn't work either. sounds like half of your carb is dead.
D
D.Hearne
11,730
south louisiana
May 31, 2008
  • May 31, 2008
You'd be surprised to know they used to use a 302 V8 as an air compressor in tire service trucks. Half the cylinders fired the pistons, the other half were the air compressor cylinders. You can remove the top half of an Autolite carb and look inside to see if there's something blocking the main jets. Take a peek and let us know what you find.
Hurtle
55
Jersey City, NJ
May 31, 2008
  • May 31, 2008
I forgot to mention that. It's an Autolite 2100. The main jets aren't blocked. However, I did find a bit of silicon gasket material at the bottom of the fuel bowl next to the valve under the float (IIRC that's the power valve). It wasn't the culprit andI have no clue how it got in there.
D
D.Hearne
11,730
south louisiana
Jun 1, 2008
  • Jun 1, 2008
If you found one piece, there's probably more. Time to take it apart and look for it.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • dan50
  • Jul 18, 2026
dan50
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
