Running remote door unlock..need idea
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Hey I'm considering running a remote door lock button on the exterior of the car, wether it be under neath or in a wheel well. What would be needed to run in terms of wiring and or switch type to work with the two wires that if I tap into the actuator power wires...any ideas would be appreciated. I'm considering using a switch that returnes to the neutral position..like a three position switch that after depressed in either direction..bit it + or - will imediately return to the neutral position to cut power to the actuator...if that makes sense.
Door lock actuators work on reverse polarity switches. Just use a test light and see weather the unlock button is triggered by + or -. I can't remember off hand.
Then just run a waterproof momentary switch and wire it up to the doorlock switch.
Actually after a quick check...your A1 on the momentary switch, I'm picking up one with the spring load to self center after use. Now I just need some creative ideas for that switch in terms of location.
Take something like this:
and hide it right up underneath your door handle. You'll be the only one that knows it's there. You'll need to run it into a relay that will complete the circuit between your "door unlock" pair of wires. The wires are small enough that you can run them inside of the door panel right where the linkage makes it's way in. Place as far forward behind the door handle itself, even folks trying the handle will not feel that it is there.
More info on that definately Daggar..do you have to correct identifying name for that item...very different, VERY good idea. 04...Daggar is on the money..something different, I don't want a remote on my keychain and this is quite simple..and different.
I gotcha...I would use it only to unlock the doors..I was being simple in my thinking and under the impression I would need to lock and unlock...thanks buddy that is a perfect Idea...would I need the relay? and what would it do??
Yes... you will need the relay. That tiny switch will not handle the current required for the door lock actuator (for long). Wire up the relay and provide a power and ground. Wire the switch in series with the relay's ground wire. When the switch is pressed, the relay will trip and complete the circuit (from the two other poles on the relay) between your "unlock" pair of wires. Let me know if you need a diagram. I can draw one up for you. Your relay will be a two position, single throw relay. Should be able to get one from any parts store.
For safety sake: You can install a 1 amp fuse between the power source and the relay but it's probably not necessary. Whatever you get power from will likely be fused already. The lock switch will have a constant power source already going to it. You can tap off of that. All you're doing with the two wires coming off of the relay is bypassing the door lock switch and giving an alternate path for the electricity to travel.
Edit:
The wiring diagram I have is tiny tiny but it looks as if the wire pair you will need are Pink/Orange and Pink/Black.
Verify this by jumpering the wires before you pernanently install the relay wires. I'll Update the pic above to reflect those colors for now.
Edit #2:
The Black/White wire looks to be the constant power source wire. (man... I really need to get some larger diagrams).
I am too tired to follow what you brainiacs are doing here but........
Andy, can Derek contain all the wiring inside his door? He could power the relay from there and tap into the lock actuator wiring right there, no?
Otherwise, if not mentioned, the lock and unlock connectors are at the top of the driver kick panel. Remove the panel for better access. There are a couple connectors - the pink wires make them easy to find.
APologies if this post was way off base. I need sleep.
Take care guys!
Take care guys!
I don't think that he can tap directly into the pair of wires going to and coming from the actuator. Not easily anyway. The polarity on those two wires reverses depending on what position the door lock switch is in. It looks like it would be much easier to tap into the switch and provide the bridge there.
An yeah... He should be able to contain all the wiring with no trouble. We're only talking about adding 4 wires inside the door. Two coming from the micro switch to the relay and two from the relay to the door lock switch. The hardest part will be finding a nice home for the new relay. There's lots of nooks and crannies in the door cavity to hide a small one.
Daggs, I actually meant to tap into the wires at the power door lock switch. It has been long enough since I worked on them though, that I dont recall the exact toggle pathway, hence me only tossing the idea out there for you smart folks to debate....... :)
Sounds like a no-go. Oh well. Carry on. :D
Yeah... sounds like we're talking about the same thing then. It sounded like you were talking about tapping power from the actuator for the relay. If the Chilton is correct, there's only two wires going to the actuator itself. That tells me that switch is alternating polarity on those two wires depentant upon the switch position. Not a good power source. My thought was just to provide a bridge for the correct two wires on the lock switch to send the actuator to the open position. If I'm reading you correctly, that's what you're talking about as well.
P.S. I would LOVE to have a BIG COLOR CODED wiring diagram covering the wall in my computer room here. :)
make a dummy key hole and run that button to it... that way it looks lik a key hole but you push it for the unlock like said above your the only one who knows its there and it not obvious to other people watching you.... that would suck if the wrong person found how to get in your ride
