running rich
  • Thread starter Thread starter sdrt
  • Start date Start date Sep 20, 2009
sdrt
  • Sep 20, 2009
my car is running extremely rich when it warms up. i have brand new o2 sensors and is giving me no codes. it will go through a tank of fuel in about 120 miles!! could it be my fuel pressure is to high? i don't have a gauge hooked up yet what should it be? thanks.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 20, 2009
  • Sep 20, 2009
Little more info on the Setup would help.
But 120 miles to a tank is crap. If its running that rich, it will have codes. Most of the Time.
Did you do both KOEO and KOER codes?
sdrt
  • Sep 20, 2009
sorry should have explained. it's a 93 lx bbk equal length,3 inch flowmaster exhaust 75mm throttle body stock injectors,pulley's smog delete,aod tranny,4.10 rear,stock manifold. when it's warm from a light you can put it on the wood and it's a pig!!.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 20, 2009
  • Sep 20, 2009
You should have codes. We need the Codes.
If you are getting absolutely no flashes, then somethings wrong.
Few things to check.
Are the 02s actually getting power?
Is the 02 signal ground hooked up on the back of the heads or intake?
Again, need codes...LOL
BlueChevelle
9
  • Sep 21, 2009
By chance did you pull the tank down? I changed my gas lines and it was running crazy rich (>60psi). The return hose had been crimped when i put the tank back up.
sdrt
  • Sep 21, 2009
i did'nt do anything with the tank. i haven't put the adjustable regulator and pressure gauge on yet.what pressure is right?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 21, 2009
  • Sep 21, 2009
40 Psi with vac line off.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 21, 2009
  • Sep 21, 2009
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
dcurtis
688
Sep 21, 2009
  • Sep 21, 2009
Are you running the 75mm tb on the stock intake, or what intake are you running.
sdrt
#10
  • Sep 22, 2009
  • #10
yes it is the stock intake with the 75mm throttle body and the kid i bought it from say's it's an e-cam but i cannot confirm that.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 22, 2009
#11
  • Sep 22, 2009
  • #11
Still waiting on the Codes from the ECM
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
