Hi all, I had an issue with my 93 notch. It was running so rough and mpg was down to 10
I had a bit of trouble in diagnosing it so I'd thought I'd throw this up just in case someone else came across the same problem
The only codes that I was getting thrown were for my egr delete (Not sure if I'd recommend that upgrade) I Originally thought that it could have been my head so I did a compression check 180 on all 4 cyl. so good there but while doing the check I discovered the #3 had fouled plugs. With no real codes to work with I assumed that the injector was bad and spraying more fuel then needed so it was replaced. Still having the same problem after replacing it I was a bit frustrated. Next day I took a trip to the junk yard and pulled a coil pack just to try it out and it was the fix.
So just thought I'd post this as it could have saved me some time and $$$
I had a bit of trouble in diagnosing it so I'd thought I'd throw this up just in case someone else came across the same problem So just thought I'd post this as it could have saved me some time and $$$
