Rust encapsulator: Should I use?
  • Thread starter Thread starter 04mustang70
  • Start date Start date Oct 11, 2007
04mustang70
88
Twin Lakes, WI
Oct 11, 2007
  • Oct 11, 2007
I am wanting to paint the undercarriage and engine bay this winter on my 70 Mach 1. I was thinking of using the eastwood rust encapsulator and then topcoating with chassis black. There is not much rust anywhere on the car so my question is do I really need the rust encapsulator? Should I forget my plan and just use a primer and paint? Also do you need to take it down to bare metal for the rust encapsulator to stick? I want a good smooth appearing finish. What is my best bet? Thanks
65fastbackresto
1,229
AR
Oct 11, 2007
  • Oct 11, 2007
I used POR 15.
This is pretty neat stuff, be sure and use the "metal prep" stuff first though, or it wont stick very well.
rusty428cj
943
267
104
Port Richey Fl
Oct 11, 2007
  • Oct 11, 2007
If it was my car I would sand it all down, clean and spray a coat of SPI black epoxy. Next day I would seam seal and the following day spray another coat of SPI epoxy black and your done. You have up to 7 days to recoat before you have to sand the epoxy.
NasaGT
1,993
Virginia
Oct 11, 2007
  • Oct 11, 2007
I tried Eastwood's rust convertor and encapsulator on the underside of our fox body stang last winter. There was rust in areas that I just couldn't sand well, and I didn't want to disassemble the back half of the car to do it. The converter made the task much easier, provided it worked. I'm going to wait a little longer before I judge their stuff - I want to see how well it holds up. So far no signs of the rust returning, but its been less than a year.
I have always used epoxy primer after removing all rust, and never had any issues. Like Rusty428cj, to me thats the best way to do it, but it takes more time to remove the rust compared to using a rust converter. And epoxy primer is a little more expensive than rust encapsulator.
04mustang70
88
Twin Lakes, WI
Oct 11, 2007
  • Oct 11, 2007
Whats SPI epoxy?
mikec35
233
NC
Oct 11, 2007
  • Oct 11, 2007
SPI is Southern Polyurethanes Epoxy.. it's good stuff. Just had my entire car blasted and primed with it. http://www.southernpolyurethanes.com/homepage.htm
04mustang70
88
Twin Lakes, WI
Oct 12, 2007
  • Oct 12, 2007
What do you mean by seam seal?
rusty428cj
943
267
104
Port Richey Fl
Oct 12, 2007
  • Oct 12, 2007
I sent you an email.
Rusty
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 10:15 AM
Kleinjj27
K
Paint and Body Strut tower beginning to break apart, how long do I have ?
  • AnthonyA1234
  • Apr 4, 2025
Fox 5.0 Mustang Tech Apr 21, 2025
AnthonyA1234
Paint and Body How should I treat this hard to reach rust
  • AnthonyA1234
  • Feb 23, 2025
Fox 5.0 Mustang Tech Feb 25, 2025
Rcdgl
R
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
Paint and Body What kind of primer for bare metal rust repair?
  • AnthonyA1234
  • May 24, 2024
Fox 5.0 Mustang Tech May 24, 2024
General karthief
