having a bit of trouble getting this thing back in. im thinking about pulling the differential out and removing the ring gear for more clearance. i would mark the ring gear so it can go back in the same spot. if i do that can i just put the differential back in and finish up with the install or will i have to check for clearances or measure anything before continuing? thanks
got it with a hose clamp. took a few tries but i was able to wedge it in by hand then a few taps of the hammer got it half way in. after that just loosened the clamp all the way and and squeezed it out. i test fit the pinion shaft and everything is good to go. going to finish bolting everything back up tomorrow. thanks for the replies
