S197 Wheels On Fox
  • Thread starter Thread starter Mavros
  • Start date Start date Dec 23, 2014
M
Mavros
34
  • Dec 23, 2014
I'm getting this 5 lug conversion when it comes back in stock:
http://www.latemodelrestoration.com/item/LRS-4234K/1987-1993-Mustang-5-Lug-Conversion-Kit
I have a lead on some stock 07 S197 wheels, will these work with the stock spindles?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Dec 23, 2014
  • Dec 23, 2014
Per the LMRS website
"1979-86 Mustangs and 1987-93 2.3L Mustangs need to use 1987-93 5.0L spindles, struts, and calipers for this kit to work.
Here is a list of wheels that will work with this kit without modification:
99-04 SVE 10th Anniversary
95 Cobra R Wheel
94-95 17" "Tri-Bar" GT Wheel
94-98 16" Waffle Star Pony Wheel
94-97 Cobra Wheel
94-04 15" V6 Wheel
94-04 16" V6 Wheel
SVE Drag Wheels
Weld Draglites
Weld Prostars
Weld Rodlites
Bogarts
Billet Specialties Street Lites
Centerlines"
Onefine88
Previously 89SSC18
1,422
796
154
Dec 23, 2014
  • Dec 23, 2014
I've seen the occasional "attempt" around my area. 2005 and newer Mustang wheels have a real deep offset. Therefore when installed on a Fox they sit waaay up under the car (narrowing the track).
In short: They look like Poop!!!!!!!
The only way to make them work you'd have to run spacers to bring them back out.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 23, 2014
  • Dec 23, 2014
It looks like the 94-95 Mustang front spindles and 94-98 Mustang rear axles are the only way to get a 5 lug setup that uses the variety of wheels that most guys like. It's time for a trip to the junkyard and getting dirty...Or maybe wait for springtime...
Reactions: cdurbin
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Dec 27, 2014
  • Dec 27, 2014
You'd need some big spacers for them to sit right. Using 1 or 1.5" spacers might just push the fronts out far enough to clear the dust cap and work. The rears will mount fine. The issue is the front dust cap on the fox brake setup, which is why sn95 brakes are usually recommended.
The main issue is tht s197 wheels will sit deep, so you need 1" or bigger spacers.
M
Mavros
34
  • Dec 29, 2014
I'm okay with getting a little dirty hitting the yards for parts... what's going on in the spring???
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 29, 2014
  • Dec 29, 2014
Rear clearance for the quad shocks when using S197 wheels?
Any thoughts or clues for this guy before he makes the plunge?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
Dec 29, 2014
  • Dec 29, 2014
Doesn't seem like a good idea.
M
Mavros
34
  • Dec 30, 2014
Thanks guys, I've decided to wait and get some spindles....anyone know of some for sale????
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Dec 30, 2014
#10
  • Dec 30, 2014
  • #10
No spacers, he would def have issues. They would have to be removed.
Only way to run these wheel is spacers, and personally, if you need 1" or more spacers to run a wheel, the wheel does not fit and should not go on the car.
SMOKUN
#11
  • Dec 31, 2014
  • #11
Wheel spacers are a bad option no matter what. I have seen too many break causing the wheel to become loose or worse.
M
Mavros
34
#12
  • Dec 31, 2014
  • #12
Found a guy locally that is parting out a 98 GT, any significant reason why those spindles wouldn't work? Only reason I ask is cause I see people saying 94-95 spindles.
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Dec 31, 2014
#13
  • Dec 31, 2014
  • #13
Just 8mm wider than 94-95 spindles.
Pushes the wheel out further but also increases the turning arc of the front wheels. With spacers this might be an issue. Running while turning could be a huge problem. You could have some serious rubbing issues while turninh
M
Mavros
34
#14
  • Dec 31, 2014
  • #14
I guess I should've said I passed on the S197 wheels and will probably go with some earlier style wheels so I won't be needing spacers
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
Dec 31, 2014
#15
  • Dec 31, 2014
  • #15
Stick with 94-95 Spindles.
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Dec 31, 2014
#16
  • Dec 31, 2014
  • #16
In that case....stick with 94-95.
If you get a good deal on the 98 parts, take it all and ebay the spindles. You might get $200. Then just get the 94-95 versions
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
3K
Fox 5.0 Mustang Tech Today at 10:18 AM
jaygee15
J
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
