Same problem again!
  • Thread starter Thread starter interceptor7
  • Start date Start date Sep 5, 2006
I
interceptor7
59
  • Sep 5, 2006
Some background: I recently resurrected my stang to daily driven status. about 3 weeks ago I washed the engine bay, and even though I was careful to cover the distributor and coil, the engine developed an idle problem. Basically, you crank it on, revs to about 2K RPM (normal), and then it drops momentarily to about 500 RPM and sputters like it wants to die. Then it comes back up and settles about 8K, but it stays pretty uneven, like I have a bigger cam (engine is stock, just a CAI).
A lot of people suggested I change the cap and rotor, and since it was over due for it anyways, I changed cap, rotor, plug wires and plugs. I used MSD cap&rotor, FMS wires, and Autolite platinum plugs.
Well, the problem went away for a couple of days, but yesterday it started doing the same thing. The old plugs didn't look bad, but the 1 to 4 plugs were a little rusty (I guess normal since they were about 2 years old).
Any help would be greatly appreciated.
I
interceptor7
59
  • Sep 7, 2006
Bump
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 7, 2006
  • Sep 7, 2006
See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=534062
for help with your idle problems. The first post contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
I
interceptor7
59
  • Sep 7, 2006
I've seen that (very thorough, BTW), but isn't a surging idle one that climbs, and stays up? Mine actually drops too low on starting(500pm) then stumbles back to 800-900 and stays there, but pretty uneven (fluctuating between 700-900). You can also feel the vacum changes on the brake pedal. I don't think is a vacum leak, because it started right after washing the engine.
9
90bluegt
592
  • Sep 7, 2006
Nope, a surging idle is one that bounces around. How did you clean the engine, maybe you cleaned some gunk off that started a chain reaction.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Sep 7, 2006
  • Sep 7, 2006
Idle air control motor, unplug it and watch the idle go smooth
I
interceptor7
59
  • Sep 7, 2006
Is that the IAC that's attached to the throtle body? I'm guessing unplugging it is not the permanent fix.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Sep 8, 2006
  • Sep 8, 2006
Well clean it out, yes its on the tb
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Defective PIP sensor ?
  • bock
  • Sep 5, 2025
2K
Fox 5.0 Mustang Tech Oct 11, 2025
Mindseye007
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
  • brandyn200
  • Jun 20, 2026
AeroCoupe
