I get codes 41 and 91 in CM and KOER tests. I have checked for vaccum leaks many times, Im almost positive its not a vaccum leak...The car stumbles alittle when I first start it. It will stubmle from idle to 1000rpm. Then after driving for about 10 min the CEL comes on and it doesnt stumble, and the car seems to loose power...I can tell you its not the following items cause I replaced them: the EGR valve, vaccum lines, O2 sensor, new wires, plugs,cap...I have cleaned the following parts: Maf, set tps, set timming 10*, cleaned IAC....the car idle OK...it kinda bounces from 800-700rpm...surging idle slightly...cant tell if its cause of the cam or not....One thing that concerns me is the fuel pump...when the CEL comes on at that same time you can hear the fuel pump start to whine slightly...but it wines sometimes with the CEL off. Here are some other problems If they affect the car running lean...there is 2 holes, 1 in each cat where the smog tube goes, that tube isnt there so there is an exhaust leak. I doubt that will cause it to run lean becuase the holes are after the O2 sensor,so I doubt fresh air is going to travel upstream against the flow, and cause the sensor to read lean or something...I also checked to see if the O2 sensor are even getting power...they are, it seem that the new o2 sensors are working properly...If somone can help be before I go crazy and sell it cause Ive been chasing these codes for aobut 3 months...Ive went through the car and checked it for loose connection, bad hoses etc...I have found nothing....
