Sandblasting DIY?
  • Thread starter Thread starter Zooted_plus
  • Start date Start date Jun 20, 2009
Zooted_plus
152
Dublin, CA
Jun 20, 2009
  • Jun 20, 2009
I've been tearing my '65 coupe down to a shell for a while now, have got just about everytthing minus front suspension/steering stripped from the car. My question is... I have a 40 gal sand blaster.. what grade of sand do I want to buy and roughly how much?? I plan on getting the proper technique down on old parts that I don't plan on reusing before I tackle the parts I am reusing. Any help is appreciated.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jun 21, 2009
  • Jun 21, 2009
The most important thing to use is caution. Sandblasting can easily warp the sheetmetal into unrepairable ripples.
Tony R
102
Vancouver Wa
Jun 21, 2009
  • Jun 21, 2009
I went to Lowes and bought bags of sand off their shelve. IIRC it was medium grit playground sand. The pot size is not as important as the size of your air compressor. I have a 60 gal and it was not big enough. It did the job but I was waiting for the compressor to fill up all the time. I used the biggest blaster that Harbor freight had and I recommend buying a couple of their nozzles they are only about 10 bucks but I wore out a couple of them. You may have to scrape your under coating off first. My blaster wouldn't take it off. When and if I do it again I will rent a big commercial size compressor. It would have only taken me a fraction of the time it took me with my 60 gal compressor.
ultrastang
1,092
Arkansas
Jun 21, 2009
  • Jun 21, 2009
'67 after I scraped the undercoating off:
After I sand blasted the area:
With 1st coat of primer applied:
All of the front end of the engine bay [inside and out], has since been blasted and primed.
I used a Craftsman siphon-feed 120# capacity sand blast hopper [similar to this]:
Campbell Hausfeld 9 Gallon Sand Blaster
My compressor is big enough I never had to stop to wait for it to catch back up so I could continue on:
This is the main reason I bought a large compressor, since I blast a lot more smaller objects --rather than the occaisional large object like a car:
Until fairly recently, objects like drive shafts or rear end housings had to be blasted outside. I made a modification to my [48"] wide cabinet to make it expandable out to 72" with the adaptable 30-gallon drum [by 14½" diameter] add-on:
1960 T-Bird 9-inch rear end housing inside cabinet:
When an object will fit inside the cabinet without the need for the extension, the drum can be removed and the hole capped off with the drum head to keep the blast media from building up in the drum:
Some of the items shown from the '67 that have been through the bead blaster:
Platonic Solid
1,960
CT-USA
Jun 21, 2009
  • Jun 21, 2009
Another non-sandblasting method you may want to consider:
73 Mustang Wheel Well Restoration
For smaller parts, I let them sit overnight in a gallon of carb cleaner- then wash with Por15 Marine Clean - then wire brush - then Acid etch with Por15 Metal Ready (which is just Phosphoric Acid) - then finish with etching primer or Por15 converter.
Each method has its pros and cons. Another rust removal option for small parts is electrolysis, but I haven't personally tried that yet.
ultrastang
1,092
Arkansas
Jun 22, 2009
  • Jun 22, 2009
...Another rust removal option for small parts is electrolysis, but I haven't personally tried that yet.
Hmmm...this could be a multi-purpose thing. It could also double as a personal hair removal devise.
NasaGT
1,993
Virginia
Jun 22, 2009
  • Jun 22, 2009
ohhh, that 30 gallon drum mod is awesome!
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
J
  • JRC99
  • Apr 19, 2025
JRC99
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
