Forced Induction Sc General ?'s
unless you plan on using an FMU which I do not recommend, the 24# injectors are not enough. As mentioned I would go with at least 42's and a 255 walbro fuel pump. You will need a tune to dial the setup in and avoid going boom.
... and if you are planning to use an FMU then that 190 will likely bypass internally before reaching the necessary fuel pressure.
