SC or idler squealing noise...? Help?
DogVomit
192
Tampa, FL
I have about 4000 miles on my Vortech SQ... All of a sudden, I've noticed an intermittent squeling sound coming from near to the blower. Could even be the idler. It queals (screach, screach screach... on and off) with the speed of the RPMS.
I tries spraying belt dressing, for process of elimination... starting with the belt, but it's still doing it, when I start the motor cold.
Has anyone encountered this?
Have any idea's how to locate the source?
Any suggestions?
Thanks guys.
jstreet0204 said:
Does it quite down while you are spraying the belt dressing?
It doesn't do it when the motor gets good and ward. When I sprayed the dressing on, the motor was pretty much warmed up. It did go away after spraying for awhile.
Thing is, I let it cool down, started up and it did it again, until it warmed up again... Just don't know.
DropTopPony said:
the idler pulley has been known to squeal....they are not expensive to replace.
Thanks... The next time I start it, I will spray some WD40 by the pully bearing to see if it quiets down at all.
As a side note, once the AC is turned on, the squealing pretty much stops = load eliminates the squeal.
