Scat 331 Stroker Rotating Assembly, H-Beam Rods, Probe Pistons, Built for Boost!
RyanSG
286
Allentown, Pa
I have the parts listed individually but I figured I would add them as a kit and see if anyone wants to go that route. Heres the info!
Everything Shipped for $500.00
The rotating assembly came out of my Mexican block based turbo stang. I made 595RWHP on the setup with a T67 Turbo. It's balanced to 28oz, and the matching dampner is for sale as well if your interested.
The crank is in great condition and has never been damaged or cut down etc. I'm the only owner and it's only been in one block. Pro installed etc, the only thing i've touched was to remove it and clean it up/re oil it down for safe keeping. The specs are in the link from summit racing.
SCAT Engine Components 93023 - Scat Cast Crankshafts - Overview - SummitRacing.com
Rods:
They are Scat, 4340 H-beam rods, 5.4" Length with ARP bolts. Perfect condition.
http://www.probeindustries.com/Produ...Show=TechSpecs
Pistons:
Probe SRS Race series, T-61 forged aluminum pistons, .030 over bore. Floating wrist pins. -14.2 CC dish with the twisted wedge cut pistons, which will also fit a regular heads as well, the twisted wedge cut just allows them to be fit to the TW heads. One of the pistons is currently damaged so you'll need 1 new piston. Last I looked for rings and 1 piston from Probe it was $120 for the rings+piston. I paid $477.00 New for the set. http://www.probeindustries.com/Produ...Show=TechSpecs
