Screw in studs - Replace with bolts?
  • Thread starter Thread starter Hickfied
  • Start date Start date Jun 23, 2007
Hickfied
413
Morganton, NC
Jun 23, 2007
  • Jun 23, 2007
I have some Moser axles with screw in 3" studs. The way it sits now, I can't mount my rims to the rear because I have closed ended lug nuts, which I have open ended nuts on order, but it will take them a week or two to get here.
Would it be safe for a 4cyl seeing no track time to just use shorter grade 8 bolts untill I can get the proper lugnuts?
1991vert
1,103
Ludlow, MA
Jun 23, 2007
  • Jun 23, 2007
are you talking about replacing the studs with bolts? or replacing the lugnuts with grade 8 nuts?
if it's the nuts, then no. the lugnuts are usually acorned. i, myself, wouldn't feel comfortable with driving around on hardware bolts, either.
Hickfied
413
Morganton, NC
Jun 23, 2007
  • Jun 23, 2007
The studs themselves, not the nuts. I have the proper nuts on order.
I am running Prostars, they have a shank on them that go into the wheel, and do not have a acorn.
Hickfied
413
Morganton, NC
Jun 23, 2007
  • Jun 23, 2007
F it, Mr Gasket is listed on Summit as grade 8.... Time to get this bastard back under the car!
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
