  • 1994 - 1995 Specific Tech
seafoam
  • Thread starter Thread starter will_95gt
  • Start date Start date May 5, 2007
will_95gt
298
Austin, TX
May 5, 2007
  • May 5, 2007
I'm sucking the foam in through the break booster hose, do i disconnect the hose from the break booster or do i disconnect it where the hose meets the plastic fitting to the right of it.
Thanks guys
EDIT: finished seamfoaming heres the vid:
http://www.youtube.com/watch?v=xhwifIPh80U
jtb19nh
156
May 5, 2007
  • May 5, 2007
disconnect it from the brake booster, also give it a little gas while sucking the seafoam thru!!!!!!!!!
will_95gt
298
Austin, TX
May 5, 2007
  • May 5, 2007
alright, i got it in, let it sit about two hours and then took it for a spin. I set up the drive-cam while i did it so i'll show you guys a vid of the smoke results when i get it on the computer lol
Z
zZsKyZz
503
May 5, 2007
  • May 5, 2007
Haha, I just seafoam'ed mine before I changed the oil and damn did it smoke! It's even better than burning the tires off
will_95gt
298
Austin, TX
May 5, 2007
  • May 5, 2007
mine didn't smoke as much as i'd hoped after 150 thousand miles... but anyways you guys can see for yourself:
nickgt5.0
96
Snohomish
May 6, 2007
  • May 6, 2007
where did u get seafoam and how much was it
will_95gt
298
Austin, TX
May 6, 2007
  • May 6, 2007
most autostores have it, i bought one can from Oreily's for 6.50 or something like that.
nickgt5.0
96
Snohomish
May 6, 2007
  • May 6, 2007
alright thanks
nickgt5.0
96
Snohomish
May 6, 2007
  • May 6, 2007
hey i got a can. where is the break booster hose? and did you do 1/3 booster, 1/3 gas/ 1/3 oil?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 6, 2007
#10
  • May 6, 2007
  • #10
You are only supposed to let it sit for 5 minutes. I think afdter that the stuff it eats up has time to settle back.
I used almost the whole can in my brake booster, and another can in the gas.
nickgt5.0
96
Snohomish
May 6, 2007
#11
  • May 6, 2007
  • #11
well i used to whole can and its smoked like everyone said it would. i also think it idles alot smoother. still have to clean the maf. thanks
will_95gt
298
Austin, TX
May 6, 2007
#12
  • May 6, 2007
  • #12
yeah i actually read the instructions for it from some transam website, they recomended about two hours before starting it up...
I did a half a can because i only could afford one can when i was at the store lol and then i did another half can in the gas tank...
Btw, if you do it in your oil i read you should change your oil about 500 miles later. I just changed mine so i'm holding off on seafoaming the oil tank.
nickgt5.0
96
Snohomish
May 7, 2007
#13
  • May 7, 2007
  • #13
yeah i need a oil change, BAD. so theres some motivation.
will_95gt
298
Austin, TX
May 7, 2007
#14
  • May 7, 2007
  • #14
lol, whatever gets you moving... i think i went past my oil change date about 2 months before my last one.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Heater Tube Delete - Plumbing
  • RotFox90
  • Jun 29, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 19, 2025
from6to8
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
