Sounds like you might be in over your head here, and this barage of suggestions is only making matters worse.law said:No I do not know where the crankshaft is. I assume I have to get under the car right?
law said:Okay guys, well I think I found the problem. My harmonic balancer is out. I got under the car and saw the rubber sticking out of the side. So I am going to attempt to replace it this weekend. Hopefully it is something that I can tackle with your help. The only thing I need to know is if the Pioneer harmonic dampner from Autozone is worth it. I do not have time to order anything online because I need to do this as soon as possible because I need my car. Or should I try NAPA? Thanks for your help.
Ouch! You found those items in a search, when I had tried to help and listed all those things in my last post on this thread.law said:I did a search I found that I need PB plaster, anti-seize, RTV or ATV for key groove in balancer and washer for cranck bolt. Can anyone tell me what the PB plaster is for and anti-seize?
Yep, I think I got my PB at Autozone. Any parts store should stock it.law said:Thanks HISSIN50, I am gonna need it. The PB plaster I can pick up at any auto parts store, correct. I will check it online, thanks again.
HISSIN50 said:Ouch! You found those items in a search, when I had tried to help and listed all those things in my last post on this thread.
