Seat Swap
iblue
29
What is the deal with swapping seats in from a 99-04 mustang into a fox body? Do you just need to keep the sliders from the fox and put them on the 99-04 seats?
Thanks
The 94-04 front seats with their tracks will all bolt up perfectly to the Fox floor. Ford did not change the floor bolt locations from 79-04. The 94-98 seats you can, if you want, put the Fox tracks on and you may just have to drill new holes in the tracks to match the seat's bolts. The 99-04 seat bottoms were designed a bit differently, and are not flat like the 79-98 seats, so if you use the Fox tracks on a 99-04 seat, you will have gaps that will need washers to mount the seat tracks flat.
Either way, I really prefer the more heavy tracks from the later model cars. Safer IMO and they look better. They are not the flimsy sheet metal type tracks like the Fox ones, but if you want to save weight, then the Fox ones are lighter.
Good luck.
Mustang5L5 said:
Did you keep the driver's power seat functional??
Sure did Mike. I combined the lumbar and seat track power into one spade connector and the ground was the other. The 4th wire was for the seat belt, which you could probably use if you got the 99+ belts too. Here is a pic of the wiring, sorry it is so big:
