seats and headlights
  • Thread starter Thread starter 65fastback2+2
  • Start date Start date Apr 4, 2004
First Prev 2 of 2
meweehaa
202
Northeast PA
Apr 8, 2004
#21
  • Apr 8, 2004
  • #21
Couldn't you just as well run newer heavier gauge wiring to you rheadlights and do the same thing without having to add more stuff to your car and what about the brake lights they are dim as crap too.
63_Fairlane
215
Greenville, SC
Apr 8, 2004
#22
  • Apr 8, 2004
  • #22
Larger gauge cables and fresh terminals and connectors will definately help.
67CoupeDriva
165
South Carolina
Apr 9, 2004
#23
  • Apr 9, 2004
  • #23
Don't forget about the 40 year old stock switch. If all you do is run larger cables to and from it it will be the bottleneck for current. And since the circuit breaker lives in there, you may get the infamous flickering headlight syndrome.
I only say that because it would be as much or more work to run the heavier cables, and you may still have problems.
Honestly, all I did was cut the short wire that goes from main harness to the headlight on the passenger side. I wired the low beam side to one relay, the high beam side to another relay.
Then I took my heavy wire (I think I used 10 ga, if memory serves) and ran it from the relay to the socket that I removed from the other end of the cut wire. I bought a new socket for the right headlight and did the same thing (low beam relay operates both lights). Ditto for the high beam side. I ran a ground wire also from the headlight sockets to a good grounding point (this is optional but insures good current flow).
Then just run a FUSED full-power source (I'm coming from the battery side of teh solonoid) to the relay, add a ground for them, and you are set.
To go back stock, all I need to do is remove the relays and my new "wiring harness" ('cause I taped it up all pretty like), replace the stock short wires from the main harness to the headlights, and I'm back to the old. Not that I plan to do that anytime soon.
First Prev 2 of 2
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Headlight wiring
  • Mattjhop23
  • Apr 21, 2024
Fox 5.0 Mustang Tech Apr 24, 2024
Mustang5L5
J
Fuel Fuel pump does not prime
  • justadude07
  • May 26, 2025
Fox 5.0 Mustang Tech May 26, 2025
justadude07
J
