Secondaries not engaging?
  • Thread starter Thread starter Alarus
  • Start date Start date Dec 29, 2005
Alarus
226
Az
Dec 29, 2005
  • Dec 29, 2005
How can i tell if my secondaries are engaging? other than climb out wile a friend is on the gas to look at it how would i tell? i dont think there engaging...
J
johnsstang04
80
Phoenix, Arizona
Dec 29, 2005
  • Dec 29, 2005
get some tie straps and stop them from opening, then take it for a ride. if there's no difference than they aren't opening. (easy way for passing smog too)
Alarus
226
Az
Dec 29, 2005
  • Dec 29, 2005
Dont have to pass smog, live in the mountins (superior) if they arnt opening, how would i fix that?
J
johnsstang04
80
Phoenix, Arizona
Dec 29, 2005
  • Dec 29, 2005
you obviously have vacuum secondaries, so there should be a diaphragm with a spring that regulates when the secondaries open. you might want to pull the diaphragm off and see if its seated properly or torn. this should be included with any standard carb rebuilding kit, so you might just want to replace it. the car generally needs a load on the engine before the secondaries will open, so revving your engine and watching the carb is useless.
you're lucky u live in superior.... stupid maricopa county!!!
Alarus
226
Az
Dec 29, 2005
  • Dec 29, 2005
alright, ill have to check it out when i get it back on the street, i have the steering box removed right now for rebuild, the back seal is shot...
D
D.Hearne
11,730
south louisiana
Dec 29, 2005
  • Dec 29, 2005
If you've got a Holley, remove the secondary diaphram housing, remove the top cover and look to see what spring is there. If it's a black or brown spring and your motor is stock or mildly built, the secondaries will not open until the engine hits around 4500-6000 rpms ( if at all) install a white or purple spring ( you'll need a Holley spring assortment kit to get these) and I guarantee they'll open fully and about a second or two after you nail the throttle. There's usually two different white springs in the pack, chose the one that looks to be the lightest.
Alarus
226
Az
Dec 30, 2005
  • Dec 30, 2005
not a holly, traded my 2bbl out for a carter 4 bbl, the holly i have is in good shape it was just a nusince to keep getting under the hood to retune it....if i remember right its done with a waight...
D
D.Hearne
11,730
south louisiana
Dec 30, 2005
  • Dec 30, 2005
Why'd you keep retuning it? Once a Holley is set it stays that way. Only thing that happens that would require fiddling with one, is dirty gas, or the ignition getting out of tune.
rbohm
6,698
550
204
tucson,az
Dec 30, 2005
  • Dec 30, 2005
on the carter, you actually have mechanical secondaries, but it uses an air valve to control the secondary airflow. make sure this air valve is operating freely. once airflow overcomes the weight of the bobweights on the air valve, the plate opens, and you should hear a hissing sound that gets louder as the plate opens.
Max Power
1,774
St Paul
Dec 30, 2005
#10
  • Dec 30, 2005
  • #10
If I remember right, you have mostly a stock 302. Quite often people new to this hobby, especially those with milder engines, expect a lot more than they get when installing a 4 barrel carb. I have heard a hundred times over the years when people first put on a vacuum secondary carb (or smooth mechanical one) they they don't think the secondaries are opening. 99.9% of the time they are.
Alarus, why do you think they are not opening? Are you comparing this with previous performance on the same car or woth your expectations?
Alarus
226
Az
Dec 30, 2005
#11
  • Dec 30, 2005
  • #11
performance between the 2bbl and 4bbl and the intakes, it accually droped a little, that and its a used carb (out of a yard) i did rebuild it however, im looking at getting a new edelbrock 4bbl but thats quite a wile away
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
