Sensor on firewall SD engine
  • Thread starter Thread starter 93 LX
  • Start date Start date Sep 8, 2007
93 LX
3,081
Norwalk, CA.
Sep 8, 2007
  • Sep 8, 2007
Problem: Engine will not idle, engine surges and idle varies between 600 and 1200 and then will die with this sensor pluged in. I removed the vacuum line and then engine idles better but still dies. I unpluged sensor all together and the engine will run. The engine still has misses at speed so i am still not sure this is the problem.
Question: What does this sensor do?
Note: Tried sensor in my 93 MAF 5.0L and did not notice any difference. I am not sure this is the problem.
Can anyone shead some light on this sensor and it's function?
Allen
stang&2Birds
2,091
New England. :-) CT/MA
Sep 8, 2007
  • Sep 8, 2007
That's the MAP sensor. You could call it the primary sensor in a n SD system - similar to the MAF in a MAF-based system.
You MUST read the codes!!!! Or, get ready to WASTE THOUSANDS of dollars GUESSING on problems!
BTW: Stay away from the POS Autozone/PepBoys/etc sensors - you've been warned. Get either a REAL Ford sensor or a quality sensor from a place like NAPA. IMHO, a non-Ford sensor is worth as much as dog-s**t.
Oh yea, an non POS MAP sensor goes for ~$80. A code reader is ~$35.
93 LX
3,081
Norwalk, CA.
Sep 8, 2007
  • Sep 8, 2007
I got the codes and they really dont tell me much. When the BAP sensor installed the engine dies. Without it, it runs albeit badly. I get the code 11 with KOEO and with the BAP installed I can not run KOEO tests. I have not run it yet without the BAP because I am sure running with out it may cause errors. As mentioned before the sensor worked fine on my 93 although it is not used the same way in a MAF car.
Allen
stang&2Birds
2,091
Sep 9, 2007
  • Sep 9, 2007
Uhm, it's a *MAP* on an SD car. It's a BAP on a MAF car.
Without the MAP, you can NOT get an "all okay" from the EEC. The EEC has a checksum that says that the PROM and CPU are good. The MAP produces a FREQ that the EEC reads. If that FREQ is not within the correct range with the engine off and key on (same function as the BAP in a MAF car), then the EEC will produce an error code.
93 LX
3,081
Norwalk, CA.
Sep 9, 2007
  • Sep 9, 2007
I get the code 11 with the device plugged in. I have tried 2 computers and both give me a 11 on KOEO tests. SInce the engine does not run with the BAP pluged in I am assuming that I will get BAP related code when doing a KOER test correct?
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Sep 9, 2007
  • Sep 9, 2007
Well code 11 means everything is fine.
Plug the sensor in and try to run the codes with the engine off. The first KOEO are meant to be read with the engine off
stang&2Birds
2,091
Sep 9, 2007
  • Sep 9, 2007
Do the following:
1) Run the KOEO tests without any BAP/MAP. Make sure you see the MAP error!
2) Plug in the *MAP*, run the KOEO tests again. You should get a code 11. If not, plug in the *BAP*, and run the KORO tests again. With the *BAP*, you should get a code 11.
If you don't get a code 11 with the *MAP*, but get a code 11 with the *BAP*, then the MAP is bad - get a new one. It's that simple!
You may still get a code 11 with the MAP and it still may be bad. First, make sure that the vacuum line to the MAP is good and is not kinked. Also, the vacuum line should be a BIG line and be connected DIRECTLY to the intake.
Because of the cost of a new MAP, you should try to be sure you need one. Of course, the other way that I look at it is that after *20* years, buying a new FORD MAP is a good idea.
93 LX
3,081
Norwalk, CA.
Sep 13, 2007
  • Sep 13, 2007
So a system ok code 11 maens my BAP is bad? Another issue is the engine is running very rich. Plugs are black. Could a bad fuel regular cause this? It does not leak gas through the vacuum line but I am at a total loss as to what is causeing this issue. I thought is was a vacuus leak but I removed all vacuum lines and it still runs rich. O2 sensors are less then 3 months old, replaced with Bosch sensors. Any ideas on how to trouble shoot this? KOEO gives 11 and I can not test KOER because then I throw the tester to test mode the engine dies.
Allen
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
