Sequence Question
  • Thread starter Thread starter NY-67stang
  • Start date Start date Apr 11, 2010
NY-67stang
58
Syracuse NY
Apr 11, 2010
  • Apr 11, 2010
So I stripped the car down and on tap for repair are:
1) Both Front floor boards (just the front piece), seat pans and toe boards
2) Both frame rail floor supports
3) Replace Torque box (drivers side) and put in a TB on Pass side
4) Replace floor board crossmember
I would like suggestions on the sequence of performing the work.
Also, can I do this on the rotisserie or does it need to be on Jack stands
T
TeamEntity
130
  • Apr 11, 2010
from what i know is that i would do this with the weight on the car aka on it's wheels when at all possible. if the weight is not in the right location from what i've learned is that it's a big possibility that fitment and or overall repair quality could be comprimised when fitting the panels with the load off the vehicle. If this makes it clearer, i once welded on a pair of subframe connectors on a two post lift. well once it was on the ground the car actually sat funny do do the bow of the car once in the air. so it was done on a drive on lift. Now of course your doing this without all of the wieght in it. It may be just fine.
NasaGT
1,993
Virginia
Apr 12, 2010
  • Apr 12, 2010
I just did the driver's torque box, toe board and floor on my car. I think the order for you would be floor support, torque box, toe board, floors. Not sure when would be easiest for the crossmember. I would do one side at a time, so maybe when the second floor support came out I'd replace the crossmember. If you cut the toe board out, then the floor support and torque box gets much easier (more room to move around). I can post a link to some pics of my torque box replacement if you'd like.
Hopefully some of the more experienced restorers will chime in. I've only worked on jack stands, so thats all I know. Lots of jack stands and shims to get the car level. I think with a rotisserie you need to weld braces across the door openings and maybe across the cabin to make sure the car doesn't flex when you start cutting stuff out.
Good luck!
2+2GT
3,333
10
79
Southeastern Pennsylvania
Apr 12, 2010
  • Apr 12, 2010
Change order:
1) Replace Torque box (drivers side) and put in a TB on Pass side and toe boards
3) Replace floor board crossmember
4) Both Front floor boards (just the front piece), seat pans
NY-67stang
58
Syracuse NY
Apr 12, 2010
  • Apr 12, 2010
Thanks for the replies.
2+2GT - What are your thoughts about jack stands or rotisserie?
Since I was going to cut one floor out at a time I'm not sure if flex will be an issue but I don't want to take any chances if some of you more experienced folks think otherwise
2+2GT
3,333
10
79
Apr 12, 2010
  • Apr 12, 2010
A rotisserie is fine once all structural repairs are finished. Before that, 4, 6, even 8 jacks might be required. This one required a 10-point support frame:
It now can be supported on a rotisserie:
NY-67stang
58
Syracuse NY
Apr 12, 2010
  • Apr 12, 2010
NasaGT said:
II can post a link to some pics of my torque box replacement if you'd like.
I would appreciate it! Thanks
NasaGT
1,993
Virginia
Apr 13, 2010
  • Apr 13, 2010
2+2GT said:
Change order:
Don't the torque boxes weld to the bottom of the floor supports? I would think the floor support would have to be replaced before the torque box, or at least at the same time. But I'm a rookie restorer, you definately know what you're doing.
NasaGT
1,993
Virginia
Apr 13, 2010
  • Apr 13, 2010
Here's a link to some pics on photobucket. This is a 69, so I had to do some parking brake cable mods to the torque box that you won't have to do. I have more pics at home, if there's a pic of something that you'd like to see but its not here, I may have a shot of it, just let me know.
Drivers Side Floor pictures by FordP51 - Photobucket
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
D
Paint and Body How bad is this undercarriage rust?
  • dqureshi06
  • Dec 12, 2024
Fox 5.0 Mustang Tech Dec 15, 2024
Rcdgl
R
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
M
  • mnky99
  • Sep 5, 2025
mnky99
M
A
Fox Foxbody convertible pinch weld question
  • Augy
  • Sep 23, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2024
Augy
A
