how hard is it to install the sequential turn signals...??? just curious before i attempt to install outside in the cold....how long does it take to install?
JonJon said:It enables the middle most light so all 3 work.
Took me half an hour, it was really easy.
Depending on which kit you get, yeah.V_Eight said:So when you hit the brakes, all THREE light up!?![]()
That looks awesome!dmarco_4u said:you cant install while at the car outside.
just take the taillights out and do it inside.
and the install is pretty easy.
JonJon said:Depending on which kit you get, yeah.
Mine from webelectricproducts.com does, I think sequentialtaillights.com charges for the module to light up the 3rd light.
JonJon said:I don't even know what knee bolster everyone was talking about![]()
My instructions from WebElectricProducts weren't clear on splicing and RE-CONNECTING, I had to go by the pictures after the lights were not sequencing. Just make sure that after you splice a wire into the quick connector and the pigtail that you connect it back into the wire you cut. You'll know what I'm talking about when you do it. Basically it's harness clip from car to pigtail back to wires running to the lights. And don't worry about messing up the quick connects. Some of mine didn't hold and once you clamp it you can't "reset" it. Just get some electrical tape or more wire nuts and you'll be good to go.
