Sequentials (meter4it chase) video
  • Thread starter Thread starter AmBo
  • Start date Start date May 14, 2007
First Prev 2 of 2
AmBo
1,027
New Jersey
May 14, 2007
#21
  • May 14, 2007
  • #21
LI98GTStang said:
Looks good. Can you adjust the timing i.e. slow it down just a tad?
sadly, you can't, but it's ok
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
May 14, 2007
#22
  • May 14, 2007
  • #22
accually you can.
See, in the mistake of the shipping you got my meter4it kit and i got your web electronics kit. But i have the Modified flasher and instructions for your meter4it kit because they were shipped correctly to me. In the instructions it tells you how to use the Modified flasher and box to slow down or speed up the sequence using the brake pedal.
....But i used the modified flasher and un-modified it to replace my jacked-up stock one
AmBo
1,027
New Jersey
May 14, 2007
#23
  • May 14, 2007
  • #23
SRT Handz said:
accually you can.
Ok, let's try that one again. So I'm using the wrong flasher?
SRT Handz
Oct 10, 2004
941
23
La Mirada, CA
May 14, 2007
#24
  • May 14, 2007
  • #24
OK, when you installed you Meter4it kit did you modify you stock flasher or instal the new flasher from the kit?
AmBo
1,027
New Jersey
May 15, 2007
#25
  • May 15, 2007
  • #25
I installed the new flasher from the kit
SRT Handz
Oct 10, 2004
941
23
La Mirada, CA
May 15, 2007
#26
  • May 15, 2007
  • #26
ok, then from what i was reading, you can use the button on the controll box and the brake pedal to control the speed and set it
AmBo
1,027
New Jersey
May 15, 2007
#27
  • May 15, 2007
  • #27
Where do you see that? http://www.meter4it.com/96-04_Mustang_Install.htm
SRT Handz
Oct 10, 2004
941
23
La Mirada, CA
May 15, 2007
#28
  • May 15, 2007
  • #28
Q) Can the speed of the chase sequence be adjusted to slow it down?
A) The speed is based off the flashers speed when calibrated to the left/ right turn signal (recommended in instructions). Another option (if you wanted it to be faster) would be to calibrate it using the brake. If you push the calibrate button and then push the brake peddle "twice" at a rate equal to or faster than the flasher you can make it sequence or chase faster depending on what pattern you have selected.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 15, 2007
#29
  • May 15, 2007
  • #29
Did someone say "flasher"?
mustang90
1,209
15
58
May 16, 2007
#30
  • May 16, 2007
  • #30
with the meter kit you can do anything possible. Just press the brake pedal go back to the box and jump it and you no longer have the 3 lights sequence when you press the brake pedal. I had my car out yesterday and everyone was on my a** cause of that kit. I'm ready to sell this one, LOL. ENJOY!
AmBo
1,027
New Jersey
May 16, 2007
#31
  • May 16, 2007
  • #31
You don't like the kit?
Wait, what do you mean by "jump it"? If I could make the brake lights be solid that would be clutch.
gnat
144
#32
  • May 16, 2007
  • #32
but for how much?
ambo I've found some cool electronics which look like they may allow me to have up to 7 different styles of lighting, and timing is adjustable too. If I get the parts I'll start a homebrew thread should be fun.
First Prev 2 of 2
Splitter for Saleen front valence?
  • 2000xp8
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 3, 2026
T
Greetings from a guy who needs help with a foxbody.
  • thefonztm
  • Mar 21, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2026
L
2012 Seats in 98 GT Convertible - pictures coming
  • lparsons42
  • Aug 11, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2025
lparsons42
L
A Fox Quest! Find Vanilla Ice's 5oh
  • Noobz347
  • Jul 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 18, 2025
FastDriver
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
