SERIOUS PROBLEMS --- ???s
  • Thread starter Thread starter 95.0Stang
  • Start date Start date May 31, 2005
9
95.0Stang
538
Kansas
May 31, 2005
  • May 31, 2005
Alright on an 87 5.0 5spd, no real mods...turbo mufflers by previous owner.
2 MAJOR problems.
I have a parisitic power loss, jump the car, and it will run. Tested the alternator and get the normal voltage, new battery, and it tested normal. Leave the car for an hour, and nothing happens when I go to start it. No idea where the problem is coming from...
When the car is cool it runs fine, let it get up to operating temp, and hit 3500 rpm, and the thing just dies. It seems to be in conjunction of when the thermostat opens. What is happeneing here?
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
May 31, 2005
  • May 31, 2005
Check grounds and vacuum leaks first
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 31, 2005
  • May 31, 2005
Typically it is something draining the battery. Small things like glove box or courtesy lights are often the culprits. If you have an aftermarket stereo or alarm system, it is also suspect.
The ideal method is to disconnect the positive terminal, and connect a Digital Multimeter (DVM) between the positive terminal on the battery and the positive cable. Set the DVM on a low current scale of 2-5 amps if it doesn't auto range. Watch the current draw, and then start pulling out fuses. When you see a sudden drop in the current, that circuit is the likely culprit. Note that the computer, radio & clock will draw less than 1/10 amp to keep the settings alive.
Performance problems at 3000 RPM or more that occur only on a warm engine are usually related to a failing TFI module.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
