  • SN95 4.6L Mustang Tech
Serious stumbeling idle
  • Thread starter Thread starter kylebgt
  • Start date Start date Mar 30, 2008
kylebgt
  • Mar 30, 2008
This is a prob my car has had ever since I bought it. Say I am backing out of a spot, when I push the clutch in to get out of R the rpm's will drop so low that it will almost die It does this when just sitting in nuetral, the rpms will sometimes bounce between 900-300-1000-700-250-900 you get the point up down etc. What is causing this? I have replaced the tps etc. etc. so those tips won't work. Thanks!
the98stang
2,408
Clovis, CA
Mar 30, 2008
  • Mar 30, 2008
Sounds like the spark plugs to me. If it was a vac problem you would have a constant high idle. Pull one of the plugs and look at it. Replace all of them if needed.
blkhorse
345
Mar 30, 2008
  • Mar 30, 2008
have you cleaned or replaced the Iac? check for leaks on intake tube between maf and tb?
streethorse
1,042
Dallas Texas
Mar 30, 2008
  • Mar 30, 2008
sounds like the IAC
fudleyd
180
Littleton, CO
Mar 30, 2008
  • Mar 30, 2008
streethorse said:
sounds like the IAC
I agree, exact same symptoms mine had...
kylebgt
  • Mar 30, 2008
I replaced the IAC last year I guess I will give that a try.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
