service engine soon light
kstng50
68
South Jersey
my light just came on yesterday and i got it pulled today and it was P0133 Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1.
I was thinking of getting an x pipe with cats will i still need to replace the O2 sensor if i put a new x pipe on. If so which O2 sensor is it refering to?
you would be better off changing it if there is a problem with it, as for the X pipe, don't waste your time with cats, the catted X pipes cost almost double the O/R, and they won't increase performance that much, I can feel a noticible difference between O/R bassani X pipe and Superchip (has Carb EO# and is burned for O/R exhaust) just hang on to your stock H pipe for emissions testing backup, usually you can pass if you have MIL eliminators, but if not, it only take an hour or two to swap the pipes and chip/MILs
