CobraG said:120 MPH, anyone know what this could be from? Car was in fourth gear, felt real strong, light stayed on until I let it coast back down to 100, then it went away.
Any ideas?
four.six said:take it to o'reillys or advance auto... they should be able to scan the code for free. good luck.
CobraG said:Even though the light went away at 100, would the code still show?
Thanks man, I'm really worried about her![]()
Has it come on since the first time? How is it running since.
Dr. Wu 2000 said:How about a lil' more info from ya. What year, any mods, how many miles. Do you have a handheld tuner? If you do you may be able to use it to scan for codes.Has it come on since the first time? How is it running since.
OuchCobracide said:A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Faulty coil (pack)
Defective computer
