  • SN95 4.6L Mustang Tech
service engine soon light
  • Thread starter Thread starter kstng50
  • Start date Start date Jul 8, 2005
kstng50
68
South Jersey
Jul 8, 2005
  • Jul 8, 2005
My light was going off and on for a few weeks now and i got the code pulled P0133 Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1. My question is I had to replace the gromet on the gas tank because it was leaking. Now after i replaced that a few days later the light went off do you think having that leak could have set the light off or should i be replacing the o2 sensor?
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Jul 8, 2005
  • Jul 8, 2005
hmm.. do you have any aftermarket exhaust on your car?
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jul 8, 2005
  • Jul 8, 2005
If I get you right... after replacing the gromet, the light went away?? Have you tried resetting the comp. and pulling codes again? If you think gromet was the cause of the P0133 code, and you fixed it, then it should not show when you pull the codes again.
kstng50
68
South Jersey
Jul 8, 2005
  • Jul 8, 2005
yeah i have flowmasters welded in with saleen center exhaust
kstng50
68
South Jersey
Jul 8, 2005
  • Jul 8, 2005
I havent reset the computer since the replace of the gromet. The light is out now will it still pull the code with the light out?
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jul 8, 2005
  • Jul 8, 2005
Some codes are stored in CM (constant memory) while others are KOER (key on engine running) or KOEO (key on engine off). If you reset your comp. and the SEL light returns then the replacement of the tank Gromet did not solve your issue with the O2 sensor.
96WhiteNight
303
Carlisle, PA
Jul 8, 2005
  • Jul 8, 2005
Reset the computer like jinx said just un plug the battery for a half hour and then go from there
kstng50
68
South Jersey
Jul 8, 2005
  • Jul 8, 2005
ill try resetting the computer and see what happens
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
