Setting Idle
  • Thread starter Thread starter ravensfan
  • Start date Start date Apr 30, 2017
1 of 2 Next Last
R
ravensfan
Active User
Mar 14, 2016
28
  • Apr 30, 2017
Ok so first I'll say my set up is block is .30 over , gt 40 heads, upper and lower intake ,maf and throttle body
Ok so I had been fighting an idle surge until I change maf sensor to 75.. now the car just won't stay at the idle I set it at, but no surge. I unplug iac , turn idle screw to where I want it, set tps, unplug battery for 15 mins , then plug iac back in.. start it up and it idles where I set it momentarily, then back down way too low , to the moment it sounds like it's going to stall..it's really laboring.. if I stab the gas , it goes up then right back to that again
Any ideas ?
R
ravensfan
Active User
Mar 14, 2016
28
  • Apr 30, 2017
Also , I wanted to add.
You know how when you start your car and the idle first goes hi , then down some, then down again to the set idle... well mine used to do that. Now, it starts high and just drops to the set idle
Is this signs of iac bad ? How can I check it ? I did replace the iac last year but I do know that doesn't mean it still working. . I also replaced the tps .
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 30, 2017
  • Apr 30, 2017
look for the surging idle checklist
R
ravensfan
Active User
Mar 14, 2016
28
  • Apr 30, 2017
The new maf sensor stopped the surging.. but now it just won't hold the idle where I attempt to set it...
Or are u saying that it's still the same parts to fix that too ?
General karthief
Mod Dude
Aug 25, 2016
28,112
10,729
213
polk county florida
Apr 30, 2017
  • Apr 30, 2017
You may have more problems or only masked the original problem, as always check for codes, make sure all your grounds are clean and tight, there are four of them under the hood and one by the computer in the kick panel on the passenger side. Also check for vacuum leaks.
Reactions: ravensfan
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 1, 2017
  • May 1, 2017
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix.
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 200,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
General karthief
Mod Dude
Aug 25, 2016
28,112
10,729
213
polk county florida
May 1, 2017
  • May 1, 2017
Sorry, thought I made a link for the sic, some days I'm lucky not to get fired. Don't tell noobz
R
ravensfan
Active User
Mar 14, 2016
28
  • May 1, 2017
i have been going thru the idle surge check list, That's why I have a new Iac, and tps, and now a new maf sensor which stopped the surging. But now , it idles to low, I have followed how to set the idle a few times, and everytime, its starts out idling ok, but soon after and at stop signs, the idle drops real low.
General karthief
Mod Dude
Aug 25, 2016
28,112
10,729
213
polk county florida
May 1, 2017
  • May 1, 2017
Vacuum leak?
R
ravensfan
Active User
Mar 14, 2016
28
#10
  • May 4, 2017
  • #10
ok, so I have installed the new maf, and the surging stopped, but now the idle wont stay stable. it wont stay where I set it, which I did according to the idle surge check list instructions. So far I have changed the maf, tps, iac, plugs, and today I am going to buy a new egr and fuel pressure regulator because I read that can cause the smell of strong fumes and bad idle.
Does anyone have any ideas if these 2 parts don't fix it ? thanks
R
ravensfan
Active User
Mar 14, 2016
28
#11
  • May 4, 2017
  • #11
karthief said:
Vacuum leak?
I have been looking for one, have not seen or heard anything yet
R
ravensfan
Active User
Mar 14, 2016
28
#12
  • May 4, 2017
  • #12
what about the O2's ? would they effect the idle at start up tho ?? I thought they didn't come into play until after the car was warm ?
R
ravensfan
Active User
Mar 14, 2016
28
#13
  • May 4, 2017
  • #13
is there a way to kinda start over ( clean slate ) on setting the idle ??? I have tried to set the idle so many times with the iac unhooked , and turned the screw so much, IS that what has everything messed up ??
General karthief
Mod Dude
Aug 25, 2016
28,112
10,729
213
polk county florida
May 4, 2017
#14
  • May 4, 2017
  • #14
Ok fresh start.
Give us a pic of the engine compartment, lets see if anything jumps out
What codes did you get, or did you not run the codes?
R
ravensfan
Active User
Mar 14, 2016
28
#15
  • May 4, 2017
  • #15
karthief said:
Ok fresh start.
I got a code 23
R
ravensfan
Active User
Mar 14, 2016
28
#16
  • May 4, 2017
  • #16
karthief said:
Ok fresh start.
I got a code 23
5.0ttops87
110
May 4, 2017
#17
  • May 4, 2017
  • #17
Throttle position sensor out of range .. check your volts to it?
5.0ttops87
110
May 4, 2017
#18
  • May 4, 2017
  • #18
should be .7 - .98 i believe
5.0ttops87
110
May 4, 2017
#19
  • May 4, 2017
  • #19
I heard you need to unplug the spout connector and iac to set it? I might be mistaken though
General karthief
Mod Dude
Aug 25, 2016
28,112
10,729
213
polk county florida
May 4, 2017
#20
  • May 4, 2017
  • #20
Here is a link to instructions
http://www.stangnet.com/mustang-forums/825424-adjusting-your-tps-0-98v-not-necessary.html
1 of 2 Next Last
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Engine Base Idle Reset-Accufab
  • 89notchDude
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 22, 2025
Scrapla347
