  • SN95 4.6L Mustang Tech
Setting pinion preload.......
  • Thread starter Thread starter bonestock87
  • Start date Start date Aug 22, 2008
bonestock87
732
12
38
Cape Coral, FL
Aug 22, 2008
  • Aug 22, 2008
I've got what is probably an overly simple question, but I need to get it right in my mind before I start my gear install tonight. When I read about setting the preload on the pinion gear, what I envision is that I'm supposed to tighten the pinion nut by hand (aka, a breaker bar), then once there is no front to back "play" on the pinion gear, start checking the preload with the in/lb torque wrench. And by preload what is meant is the amount of in/lb force it takes to turn the pinion gear with the torque wrench and socket on the pinion nut. Right? What I seem to keep second guessing is that once I tighten the nut that much it will already by way more than 16-29 in/lb. Can someone talk me down from the ledge on this one? I feel pretty confident I can do the overall job, but I'm the type that has to know EVERYTHING before I start or I get nervous.
Thanks!!
trinity_gt
3,125
81
99
Canada
Aug 22, 2008
  • Aug 22, 2008
Exactly, with no ring-gear installed.
Thanks!!
It will take a fair amount of torque on the pinion nut to compress the crush sleeve enough to generate the required preload. just remember you have to sneak up on it: If you tighten it too much and have too much preload torque, you can't just loosen the nut and start again...you'll have to remove the pinion and replace the crush sleeve at that point.
forum155pl
520
the 509
Aug 22, 2008
  • Aug 22, 2008
you need a wrench with a dial gauge on it.. once you get her tight, your supposed to put the wrench on there and turn the pinion... you want what ever your preload measurement is to match up with your dial on the wrench
make sure you use a new crush sleeve and dont overtighten the nut cuz you cant back it out without pulling it apart again and putting in another crush sleeve..
keep in mind that if you re use your pinion bearing then its going to be a tigher spec then a new bearing..
lastly.. setting up a rearend is tough stuff, i thought i could do it and it was too much. you really need a bearing press and lots of time to set her up. i tried mine and right when i drove it around the block i pulled the whole axle out and took it to a speed shop
M
mineralgraygt
187
nj
Aug 22, 2008
  • Aug 22, 2008
just take your time you have the right idea. it easy, you need one of the inch pound torque wrenched with the hand needle on it so you can see where you at. you cant use a click type. that what i use a work after you do a few you can feel them by hand and know. if your reusing you bearings i would keep it around 15. if your putting new bearings in it would go between 20 and 30 inch pounds.
bonestock87
732
12
38
Cape Coral, FL
Aug 23, 2008
  • Aug 23, 2008
Thanks, I really appreciate the replies and advice. Turns out a guy that I wanted to do the job for CAN do it after all, so I'm going to take the safe way out this time and pay a pro to do it. I will say that I learned a ton about how the rear end works through doing all my research and reading.
On another note, I went ahead and bought the inner and outer pinion bearings and races, along with Mobil 1 gear oil. The guy at Advance told me 2 quarts was enough. All told, it cost me another $87 for all that. Did I really need to get those new bearings? I don't mind having the new ones installed, but I couldn't help but have that "did I just blow money I didn't need to" feeling. Any comments/advice?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Aug 23, 2008
  • Aug 23, 2008
i cant remember the TQ spec for the pinion nut but after its TQ down you get that needle type in./lbs TQ wrench and check the rotational TQ. If you are using the old pinion bearings it is 8-14in./lbs, with new brearings it is 16-25in./lbs.....The reason they may have told you to get a new pinion bearing is because sometimes they get damged when you remove them form the old pinion when you are getting the shim out.
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
