Today right after I put on my American Thunder Flows
, i installed new rotors to get rid of the shake i have when i brake (usually from higher speeds > 20mph). So i figured that would fix the problem right? WRONG, it has the same exact, maybe a little worse shake.
Is it possible that the rotors I bought were also warped (They were cheap rotors- ~$20 each)??? Or is there another problem and if there is, any suggestions???
(This is a shake occuring during braking. Usually starts with a steering wheel shake then gradually moves to the whole car)
, i installed new rotors to get rid of the shake i have when i brake (usually from higher speeds > 20mph). So i figured that would fix the problem right? WRONG, it has the same exact, maybe a little worse shake. Is it possible that the rotors I bought were also warped (They were cheap rotors- ~$20 each)??? Or is there another problem and if there is, any suggestions???
