my shifter starts to shake and vibrate terribly around 85-115mph which is when it starts to settle down.... what could be causing this? drive shaft?
If you think that aftermarket gear sets vibrate, or vibration may be a "side affect" of having them installed, then someone has told you the wrong thing. There should NEVER be a vibration coming from the rear whether the gears are OE or not. They were installed improperly if they do indeed vibrate.GTJake said:Gears shouldn't cause an RPM dependent vibration.
Jake
