Shift boot
  • Thread starter Thread starter Killerrobotjews
  • Start date Start date Apr 2, 2005
K
Killerrobotjews
62
  • Apr 2, 2005
How do i get it off? I want to see if i have an aftermarket shifter
stang22
1,318
Washington, D.C.
Apr 2, 2005
  • Apr 2, 2005
The leather part or the rubber part? The leather part just pops off, just pull on it. The rubber part has 4 bolts holding it down. Hope this helps.
Tim
Paul Perreca
1,085
  • Apr 2, 2005
pop off the bezel that goes around it (plastic, and clips becareful) using a clip puller or a screwdriver and pop it off, take off your shift knob, and the boot and plastic i believe slide off together, or you'll see where the boot is bolted.
Paul Perreca
notchback
1,950
St Clair Shores MI
Apr 2, 2005
  • Apr 2, 2005
there are 4 bolts...10mm i think
you should be able to tell just by looking at it.
is the stick steel or aluminum, is it short or tall, and is it soft or solid when you bang it around?
HISSIN50
34
129
Apr 2, 2005
  • Apr 2, 2005
notchback said:
is the stick short or tall, and is it soft or solid when you bang it around?
how will this tell him if he has an aftermarket shifter?
a set of ratcheting box end wrenches really helped with the front two bolts (notch - i think you are right. my recollection was that they were either 8 or 10 mm, and 10 sounds more likely). some folks have clearanced the stock center console itself to get access to those bolts and some remove the center console. i was able to slowly get them out with a ratcheting box end. good luck.
D
Interior and Upholstery Shift knob doesn’t connect to shift boot?
  • dqureshi06
  • Jun 10, 2025
Fox 5.0 Mustang Tech Jun 17, 2025
Kid wita 5oh
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Interior and Upholstery HVAC Mode selector vacuum switch issue.
  • parish99
  • Jul 3, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
KAWMAN2
