  • SN95 4.6L Mustang Tech
Shift kit
  • Thread starter Thread starter americanjesus
  • Start date Start date Aug 20, 2005
A
americanjesus
59
NJ
Aug 20, 2005
  • Aug 20, 2005
So I wanna put a shift kit in my auto. Is this going to be hard on a lift? any one know how long it will probally take to do? Thanks
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Aug 20, 2005
  • Aug 20, 2005
read the tranny articles here about the Jerry Mod
www.tccoa.com
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 20, 2005
  • Aug 20, 2005
That is such a great information resource. Another vote for reading TCCOA
sgarlic
3,085
Aug 20, 2005
  • Aug 20, 2005
Never done one on a Mustang, but I've done a chevy truck and a dodge truck.. both were pretty straight forward.
Install a drain plug kit on the pan while it's off, and test it for leaks BEFORE you seal it all back up.
Make sure your work area is plenty clean, replace the transmission filter while it's off, and take your time. You'll be fine if you follow the directions and keep it clean. Don't rush. It'll take probably 6-8 full hours if you go by the directions, don't have any problems.
MyEarsHurt
918
  • Aug 20, 2005
My shift kit came with a video for installation and a very detailed map of the trans. I thought I would be able to do the install myself, but it seems too difficult for me (and I did my own PI swap). I called a few different transmission shops and a few performance shops around me and NOBODY would touch the install. This kinda made me wonder if I really wanted to even risk having someone install it and mess it up....so now there is a shift kit under my bed that I dont know if I even want to mess with.
stang302v8
94
carlisle, pa
Aug 20, 2005
  • Aug 20, 2005
Trust me man, its worth it. I have a 3 speed automatic 1970 stang and with that shift kit installed it kicks like downshifting a manual trans. not only that but it gives a much harder jump when shifting under full throttle.
98blackmagic
386
wouldnt you like to know
Aug 20, 2005
  • Aug 20, 2005
I agree the shiftkit is worth the price and labor install. My 98 has a trans-go kit and my old 96 had one as well. I drove the 96 for 70,000 miles and never had a problem with the trans. My 98 is doing great too, it's a lot of fun the first time you hear your tires chirp 2nd gear in drive when you aren't even getting on it hard. I don't know why you are haveing a hard time getting one installed, all the shops I called wanted to do mine I just had to decide on how much I wanted to pay (each shop diffrent prices). Paid 200 in the end.
tomustang
Psychotic Member
3,434
McLean Hospital
Aug 20, 2005
  • Aug 20, 2005
different tranny different results. shifts-kits are usually worse for the 4R70W
tomustang
Psychotic Member
3,434
McLean Hospital
Aug 20, 2005
  • Aug 20, 2005
J-mod, tq converter, gears and a tuner to firm up the shifts will set you straight and 5sp'd too
sgarlic
3,085
Aug 20, 2005
#10
  • Aug 20, 2005
  • #10
Oh yeah.. before you bother doing any other mods to your tranny, get a nice tranny cooler if you haven't already. It'll lower temperatures and extend yourtransmission life. It's well worth it, and will look cool through the grille too.
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Aug 20, 2005
#11
  • Aug 20, 2005
  • #11
This was one of my first modifications. Heat breaks down the Meron in transmission fluid, which is the key ingredient for protection against friction. Once the Mercon is gone, the parts start to recieve excessive wear and tear. This can be avoided with a simple transmission cooler. I use the one from Steeda and I've had no problems with it. Other good companies for coolers are Flex-a-lite, B&M, and Performance Automatic( I think they make a cooler).
If not installed correctly, or using the wrong shift kit, such as shift kits that use blocker rings or require you to tamper with the line pressure, via the pressure control solenoid, then you run the risk of seriously damaging the transmission. Blocker rings are to be avoided, as they only shorted the "stroke" of the accumulator piston during shifts. This is bad news, because the accumulator piston should fully stroke when engaging gear shifts. Tampering with line pressure will result in firmer shifts, but at a potential price of starving certain internal clutches of proper lubrication. Avoid tampering with line pressure at all costs.
I agree. Read all the articles involving the Jerry mod shift kit. It will help explains things and give you a better idea of how the 4r70w transmission operates.
A few quick notes. If you're not mechanically minded, or have never worked on a transmission before, you might want to let someone else do this job. Any good transmission shop should be able to handle this for you. It involves simply pulling the stock valve body, enlarging certain holes in the seperator plate, swapping a spring in one accumulator piston, and removing a spring from the other accumulator piston. Its pretty straight forward. Be sure to pick up the new seperator plate gaskets that you will need. These are a must. I did the Jerry mod once on my car, the gasket was bad(though it looked brand new), I put it back in, and the transmission blew on me. Learn from my mistake.
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
08 Turbo kit. Who made this???
  • Don7Up
  • Oct 3, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 10, 2026
highplace11
H
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
