Shift kit...
  • Thread starter Thread starter Trefty
  • Start date Start date Feb 16, 2007
T
Trefty
117
  • Feb 16, 2007
What exactly does a shift kit do? Does it allow you to hold the transmission in any gear? How does it work with the stock shifter? Also, how hard is the installation? Thanks.
eagleautosports
139
Mebane NC
Feb 16, 2007
  • Feb 16, 2007
It isn't hard at all as long as you have basic mechanical abilities. The shifter will still operate the same. A kit modifies the amount and pressure of the fluid as it travels through the valvebody. Certain kits are better than others but most give you the ability to hold the gears but if you're thinking about the 1-3-1 shift pattern, no it doesn't change that. It's the design of the tranny (AOD) that prevents a true 1-2-3 pattern. To get that feature, you'd have to change the valvebody itself that's been modified to do that.
T
Trefty
117
  • Feb 17, 2007
Ahhh, ok, that makes sense, thanks for the help. So if I have access to a hoist and take my time the install shouldn't be too difficult.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 17, 2007
  • Feb 17, 2007
no you should be able to install a shift kit yourself.
RYC CUKR
1,437
Orlando
Feb 17, 2007
  • Feb 17, 2007
Like others have said they are pretty easy to install. With a lift it will be even easier. The worst part is lying on your back in the transfluid that has inevititably(sp) leaked all over the driveway..
Have you already gotten a shiftkit yet?
T
Trefty
117
  • Feb 17, 2007
Haven't got a shift kit yet. I hear the transgo is the way to go? Any other good options out there?
RYC CUKR
1,437
Orlando
Feb 17, 2007
  • Feb 17, 2007
Some guys have issues with the transgo shift kit shifting into OD at WOT which is a big unless you have at least upgraded the OD servo.
That said I have a transgo in my 93 and it does not shift into OD at WOT so I have no issues. It is a good kit from my experience with a hard 1-2 shift.
Another kit that people are big on the the Baumann shift kit. Their website is www.becontrols.com. Lots of pretty good info on there for AODs and you might also want to check out www.clickclickracing.com and look through forums there and post up. Pretty dedicated to auto transmissions in Mustangs and other Fords over there. LOTS of good info on that site.
ronburgundy
179
BC coast
Feb 17, 2007
  • Feb 17, 2007
transgo is the most complete kit for the do it yerselfer. do the od servo at the same time, and watch that when you reinstall the od servo that you get it in the band lug otherwise you shift 1-2-3-neutral. not cool, i'm speaking from experience.
transgo is the most recognized brand for trans. shops because their products are not only built for performance, but they fix common known issues with the transmissions they are designed for.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
D
Interior and Upholstery Shift knob doesn’t connect to shift boot?
  • dqureshi06
  • Jun 10, 2025
Fox 5.0 Mustang Tech Jun 17, 2025
Kid wita 5oh
