shift light hook up on 99+ gts
stanggt00
371
baltimore md
ok guys i just get a shift light that i want to hook up thing is i dont know what wire to hook it upto to get a signal for the light to turn on
can i hook the wire up to the negative on coil pack number 1 or no
LoneGunman said:
Exactly you will have to cut the red wire coming off of the coils going back to the connection block located by the A/C Drier and wire it through the autometer tach driver. I would make the cut and splice toward the connection block to keep it clean. Top left corner of picture is where I make the connections. and I mount the driver to the right near the middle on the fire wall.
photodisplay.php
but why would i need to splice into all of the coil packs to get a tach signal
could i just tap into one of the coil packs or to make it neat tap into the wire going to one of the coil packs near the computer to get a signal
i am thinking now that i just got a shift light that i dont need for 120.00
to go with my msd 8950 rpm window switch
i went to a few web sites and they are tapping the wire off the computer to get a tach signal and if that is true to get a signal what wires do a tach adpater connect to
o crap thxs man for the response i see that our indash tach is digital not analog so the signal is no good for a direct connection i needs to be converted hins the tach adapter
great i will save my self some money and take that shift light back and get the tach adapter so i can use my window switch for the nitros
thxs for the response bro
got me thinking now i got an msd pn 8969 electronic window switch and hooked it up to the coil pack negative wire and was getting an rpm reading thing is when i tested the input wire that was normal open it was closed but if i needed that tach adapter then maybe the dam thing was just getting a crazy signal
so i am stuck with a digital msd and the crappy one that you have to buy the pills for hehe
getting the adapter and see if i can get one of them to work then i will just sell the other one
:shrug: You lost me with "take that shift light back and get the tach adapter so i can use my window switch for the nitros"
