Shift Light Questions
  • Thread starter Thread starter 90lxwhite
  • Start date Start date Jan 16, 2015
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Jan 16, 2015
  • Jan 16, 2015
My gauge cluster in my 95 gt came out of a 95 cobra and I have no clue how accurate my tach is but I'm guessing not very since I run out of gas when I'm on 1/4 tank. So I'm thinking about getting a shift light and I'd like one that's pseudo discrete, I don't want a Mag Light hanging from my a pillar. Any recommendations? How accurate are they and how do they work? Also I'd like to mention that I really don't want an aftermarket tach, I'm trying to keep a stockish appearance.
85rkyboby
923
96
39
South ATL
Jan 16, 2015
  • Jan 16, 2015
A custom Speedhut gauge is an idea. Pricey, but a good warranty and fully customizable. I can't remember who, but I think @Noobz347 or @revhead347 had a good insight on interior gauges. Whoever will have some links.
Admin Dude
Jan 4, 1985
43,577
21,742
234
Box behind Walmart
Jan 16, 2015
  • Jan 16, 2015
I did not get that alert.
You don't wanna ask me about gauges though. I have an expensive taste in white face analog gauges that can be tough to come by. lol
Seriously though... Im the type that would do my very best to confirm that my OEM is as accurate as possible so that I don't have some big ugly "Ricky the Red Neck Racer" tach sitting on my dash.
For a shift light? I like pillar pods that house two or more gauges along with a shift light. For shift lights, I like the ones that are programmable for each gear.
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Jan 16, 2015
  • Jan 16, 2015
Raptor shift light in an ac vent is probably going to be the most sleeperish way to go about it. Programmable, and only about 3/4" diameter. Three wires: ignition on, ground, and signal (coil).
Autometer also makes several kinds, i have one that i need to install that has a digital rpm readout since i dont trust my tach for , but its larger than the raptor and not as essy to hide. Install is the same though
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 16, 2015
  • Jan 16, 2015
Where does the light get it's "reading" from?
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 16, 2015
  • Jan 16, 2015
I always had one with an aftermarket tach so I can't help with much. Just a fwiw once you do get it installed and go to a track I recommend setting it about 2-500rpm below where you want to shift at. Depending on your reflexes that is.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 16, 2015
  • Jan 16, 2015
Gotcha
elarm1
1,428
652
154
N.Va
Jan 16, 2015
  • Jan 16, 2015
http://www.latemodelrestoration.com/item/RPS-LYBLK003/Yellow-LED-Mini-Shift-Light-With-Black-Housing
Raptor is the ish! Small yet effective
Reactions: A5literMan
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 16, 2015
  • Jan 16, 2015
Those are bada**! Now LMR's going to get more of my money! I likey!
Chuckman
1,604
1,002
173
st. louis, mo
Jan 16, 2015
#10
  • Jan 16, 2015
  • #10
Signal is from the green wire on the coil, all a tach or shift light is is a pulse counter, and counts how many times the coil fires per second.
If you have an aftermarket ignition box (msd ir whatever) it will have a tach signal wire or connector because going right off the coil will kill the tach/light.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 16, 2015
#11
  • Jan 16, 2015
  • #11
Hm that's what she said, I think I might get one of those
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 16, 2015
#12
  • Jan 16, 2015
  • #12
Oh ok. I have an msd box, so it connects to that huh?
Chuckman
1,604
1,002
173
st. louis, mo
Jan 16, 2015
#13
  • Jan 16, 2015
  • #13
Yup, should have a connection labeled tach signal. Green wire from the light connects there.
Admin Dude
Jan 4, 1985
43,577
21,742
234
Box behind Walmart
Jan 16, 2015
#14
  • Jan 16, 2015
  • #14
Is there a
What is it about this one that you like? Also... The instructions/description in that link are screwed up, can you explain the functions of the two dials?
elarm1
1,428
652
154
N.Va
Jan 16, 2015
#15
  • Jan 16, 2015
  • #15
I like the ease of installation, size, and the way it performs. Yup, that's what she said!!!!!
http://www.fordmuscle.com/archives/2004/10/ShiftLight/index.php
Reactions: Noobz347
Admin Dude
Jan 4, 1985
43,577
21,742
234
Box behind Walmart
Jan 16, 2015
#16
  • Jan 16, 2015
  • #16
Ha! Nice link.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Jan 16, 2015
#17
  • Jan 16, 2015
  • #17
A better idea, this thread shows how to adjust your stock tach to be completely accurate using the adjustment pods on the back of the tach> http://forums.corral.net/forums/gen...urate-your-stock-fox-tach-results-inside.html
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 16, 2015
#18
  • Jan 16, 2015
  • #18
All one needs is a frequency generator....
Reactions: elarm1
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
J
Shift light
  • Jfriedrich
  • Jun 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 29, 2025
dirk shorter
D
