shift light ?'s
  • Thread starter Thread starter Sevan
  • Start date Start date Oct 15, 2004
Sevan
558
IL
Oct 15, 2004
  • Oct 15, 2004
I just picked up an Autometer RPM module because I am going to make my own shift light. Does anyone know which wire is the "Tach" wire off the ECU, because I need to tap with the GREEN wire from the unit. The diagram say that you can tap into the Tach terminal on electronic ignition. Below is the wiring instructions. All inputs appreciated. Thanks
http://hp.autometer.com/instructions/005310_instruction.pdf
N
notchman90
87
long isle, ny
Oct 15, 2004
  • Oct 15, 2004
i tapped mine into the coil, its one of those two wires. forgot which color but ill check for u in the morn.
HISSIN50
34
129
Oct 16, 2004
  • Oct 16, 2004
it is the one that does not show constant 12 volts. IIRC, it is the wire closest to the pass side. DO NOT ACT ON WHAT I SAID ALONE - I'm just tossing out what i recall in case it jogs someone's memory.
also, IIRC, the wire has a stripe on it (the 12 volt wire does not).
good luck.
281pony
2,681
Oly, WA
Oct 16, 2004
  • Oct 16, 2004
it is the green wire on the drivers side you tap into. just looked at mine.
HISSIN50
34
129
Oct 16, 2004
  • Oct 16, 2004
hey bud, thanks for correcting me. im glad i know enough to post when im not sure (in caps no less) so as to not have him follow my bad advice.
thanks again.
281pony
2,681
Oly, WA
Oct 16, 2004
  • Oct 16, 2004
no problem. the hood was already up even so i just walked 5 feet and looked.
Sevan
558
IL
Oct 18, 2004
  • Oct 18, 2004
88SC_GT, do u have any pics? I can't find any pics on yours
thanks
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
Shift light
  • Jfriedrich
  • Jun 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 29, 2025
dirk shorter
D
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
