Shift light wiring?
  • Thread starter Thread starter TrickFlowd
  • Start date Start date Oct 24, 2007
TrickFlowd
240
Sayre, PA
Oct 24, 2007
  • Oct 24, 2007
I got a autometer shift light from a friend. He can't find the wiring diagram.
Anyone know where the green wire goes? Obviously to the tach lead on an electronic ignition box like MSD or ACCEL...but I don't have one. So where do I wire the green? The red is power, and black is obviously ground. I have it mounted on my steering column cover...and want to use it with the stock tach.
HISSIN50
34
129
Oct 24, 2007
  • Oct 24, 2007
Autometer used to have PDF directions on their site.
The tach hook-up without a box should be the negative side of the ignition coil.
Good luck.
5.0TailPipeHump
153
Oct 24, 2007
  • Oct 24, 2007
http://www.egauges.com/pdf/AutoMeter/561.pdf
TrickFlowd
240
Sayre, PA
Oct 24, 2007
  • Oct 24, 2007
Thanks!
SuperStang83
1,693
Boyertown, Pa
Oct 24, 2007
  • Oct 24, 2007
Autometer has the instructions on their site for future reference.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:09 PM
2000xp8
