Shift Question
  • Thread starter Thread starter Mark89Notch
  • Start date Start date Sep 17, 2004
M
Mark89Notch
42
Long Island,NY
Sep 17, 2004
  • Sep 17, 2004
I was told that it is possible to shift without the clutch at full throttle after 5000 rpms and it will not hurt the tranny. Is this possible?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 17, 2004
  • Sep 17, 2004
Yes you can do it...but it is not recommended for the life and internals of your transmission...
Just use the clutch...much safer bet and you don't lose that much time if you use the clutch and shifting method properly if at all...
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
Sep 17, 2004
  • Sep 17, 2004
It's possible to do it at part throttle. It's called "floating the gears" and you need to have a VERY good understanding about matching the RPM's between tranny and engine to do it without causing harm.
DOing it at WOT will be next to impossible. First of all, the design of the T-5 prevents you from pulling it out of gear under load. The dog teeth are designed to lock together and only unlock when there is no load on the tranny (clutch pushed in, or RPM's in sync w. no load). At WOT, you'll prob need two hands to pull it out of gear.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 17, 2004
  • Sep 17, 2004
As I stated...not recommended...but possible...
Just use your clutch like it was intended for and don't worry about it...
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
