Shifter and Rack and Pinion assy replacement?
  • Thread starter Thread starter tikibeast
  • Start date Start date Jun 18, 2011
T
tikibeast
59
Victorville, Ca
Jun 18, 2011
  • Jun 18, 2011
I'm in the middle of trying to replace my rack, the old one is leaking and I wanted a faster ratio rack. The problem is separating my spindle from the ball joint, I put my 3 jaw puller on to break it loose but the puller keeps jumping off, I've done this on a few other cars without this problem so I'm at a loss, any ideas would be appreciated.
As to the shifter, I picked up the MGW shifter to replace my stock shifter, the problem I'm running into is getting the center console out, I popped the bezel out but I don't see much else holding it in place, all the same the back end wont budge when I try to pry it out and my manual is damn near useless for things like this so I'm hoping I can pick somebody's brain here.
ID89GT
1,659
18
49
Spokane Valley, WA
Jun 18, 2011
  • Jun 18, 2011
Why are you pulling the spindle off? Just undo the tie rod from the spindle
ID89GT
1,659
18
49
Spokane Valley, WA
Jun 18, 2011
  • Jun 18, 2011
As for the center console, you need to take the arm rest off first, the bolts are on the side facing the front seats. Then it will uncover the screws that are holding the back of the console down.
T
tikibeast
59
Victorville, Ca
Jun 19, 2011
  • Jun 19, 2011
Got the suspension parts torn apart, just trying to get the steering rack out now...but that'll have to wait until tomorrow when it's light out. Two flashlights and a work light aren't cutting it.
I'll have to look at it again in the morning as well, I pulled several screws out of the armrest but it still wouldn't come loose, I might be tired, or I might just be missing something in the dark. Thanks for the tip though.
ID89GT
1,659
18
49
Spokane Valley, WA
Jun 19, 2011
  • Jun 19, 2011
There are two plastic caps on the side that cover the bolts. They are long oval shaped
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 19, 2011
  • Jun 19, 2011
The two inner tie rod ends are usually what wears out, and at $45 each, it's better to get a replacement rack assembly since they are part of the package. The rack is about $100 + a $40 refundable core charge, which you get back when you return the old rack. Be sure to ask for the GT or high performance rack, it has fewer turns lock to lock than the standard rack.
The flex coupling for the steering shaft needs to be disconnected before you can get the rack out. You should disassemble the coupling by removing the 2 bolts that hold it together. The lower part of the coupling will then come out with the rack, and can easily be removed.
The tie rod ends can be removed with a tool that looks like a giant "pickle fork", it's less than $8, or some stores will rent/loan one. Remove the cotter pin & nut on the tie end, stick the tool between the rod end and the arm it connects and hammer away. The bigger the hammer, the easier it comes apart.
Remove the two bolts that bolt the rack assembly to the frame and then pull the rack down. Get a catch pan to dump the fluid in when you disconnect the hydraulic lines. I replaced the rack mount bushings with some Energy Suspension urethane ones. When you re-install the rack assembly, put the rear bushings in the rack assembly and lift it into place. Then install the front bushings & washers and tighten down the nuts. Doing it this way makes room for the hydraulic lines without having them bind against the frame.
To change the tie rod ends, do them one at a time. Loosen the jam nut 1/4 turn, then unscrew the tie rod end from the rack. Turn the jam nut back 1/4 turn to return it to its original position. With the tie rod end removed, use a machinist square to measure the distance between the end of the threaded rod and the jam nut. Sit the bottom of the square against the end of the threaded rod, and the end of the blade of the square against the jam nut. Duplicate the measurement on the new rack and then install the tie rod end and tighten the jam nut. Then do the other side: the front end will need aligning, but the toe in will be close enough to the setting of the original rack to drive.
Buy several extra quarts of fluid to run through the system to flush it when you change the rack. The car needs to be up on jackstands for the next step. Fill the pump up, start the car, and turn the wheels lock to lock to bleed the air out. Then stop the engine, disconnect the low pressure hose (the one that is secured with a hose clamp) and drain the pump. Re-connect, refill and do it several more times or until the fluid looks clear and not burnt or black.
Power steering pressure lines:
Each hose uses an O ring on each end to seal them. The hoses will swivel when they are installed and tightened into place. That is why there are O rings on the fittings. The O ring is the part that actually makes the pressure seal. If you slide the nut all the way back as far as it will go, you will see the O ring and the groove cut into the center section of the fitting.
Sometimes you will get some white Teflon rings with the pump or rack. The rings go on the threaded part of the fitting to reduce or prevent small leaks. They are not meant to seal the pressure part of the line or substitute for the rubber O ring. Heat the white Teflon seals in hot water and they will be easier to install. You can install the fittings without them and not have any leaks if the O rings seal good.
T
tikibeast
59
Victorville, Ca
Jun 19, 2011
  • Jun 19, 2011
I tried the pickle fork when the puller failed and had no luck there either, but like I said the hammer method worked just fine. Impressive write-up there though, somebody needs to copy+paste and sticky that for the future. I agree on the new rack, I purchased the "performance rack" (2.25 turns vs 3) and I'm definitely looking forward to trying it out, my only concern is when I do the 5 lug conversion in a month or two will I end up rubbing my tires with the suddenly shortened turn ratio (IE before I can compensate and stop myself from locking out). I feel 15's really are the right size for the car, but I'd like to step up to a F 235 and R 275 set up to give her some much lacking traction without rubbing every time I pull into a parking spot.
Thanks for your patience btw, I can handle exhaust work and general engine work, but suspension, body (exterior and interior both) and etc frequently leaves me scratching my head or breaking things beyond recognition (mostly in reference to interior pieces).
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
Ryu
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
